Missing /usr/sbin/zabbix_server
  • ueuei
    • Mar 2023
    After attempting to restart zabbix-server service I found out:
    â zabbix-server.service - LSB: Start zabbix-server daemon
    Loaded: loaded (/etc/init.d/zabbix-server; enabled; vendor preset: enabled)
    Active: active (exited) since Wed 2023-03-29 14:50:58 CEST; 2h 5min ago
    Docs: man:systemd-sysv-generator(8)
    Tasks: 0 (limit: 14276)
    Memory: 0B
    CGroup: /system.slice/zabbix-server.service
    and I realized there is no /usr/sbin/zabbix_server start file
    I have a "doppelganger" server where I could retrieve it, do you think copying it back will do the magic?
    Or I may have any other way to restore/recreate it?
    • 4996
    You should investigate, what removed that file/package. I suspect there is more than just one file missing...
    Better would be to reinstall it...
    • ueuei
      • Mar 2023
      Yes I have the same doubt but after all is a try.... ideally if it is the only file missing then this should work.
      In case of reinstallation, can I just reinstall only the zabbix-server component and skip everything else (db is already there and working, agent also, etc...)
