Some backround info:
So, I Installed about ~3 weeks ago Zabbix server and proxy server while proxy server was physically where I am, and everything worked just fine. Server and proxy were installed into different networks and they communicated as they were supposed to.
However now that we moved proxy server to its final location, then we made VPN configurations etc etc. Now proxy won't give us any data back to server. Connections do work, they have been tested several times and if I make some changes to hosts that proxy is supposed to gather data from and bypass proxy server I still can get information from them if they are monitored directly from central server.
Now to the problem:
If I put my hosts that proxy should gather information from behind that proxy, agents are giving error "Get value from agent failed: cannot connect to [[XXX.XXX.XXX.XXX]:10050]: [4] Interrupted system call" even tho they are configured to be found from YYY.YYY.YYY.YYY:10051, IP that error gives is from the time when that server was physically at my location.
So the question is, what makes proxy to behave so weird, why doesn't it update those IP's to new ones, even tho every agent configuration is done "properly"? And where do those old IP's come from, I found some old ip's in database in proxy, deleted them, forced cache reload but still nothing.
Thanks in advance, hope someone could identify or point me to correct way.
Now to the problem:
