Varnish Cache Template problem
  • ekkljs
    • May 2016
    I am running Zabbix 2.4.8, Varnish 4.0.3 and try to monitor Varnish by applying varnish cache template from https://github.com/allenta/zabbix-te...-varnish-cache.
    Checked cron log, zabbix agent log and it seems everything is setup correctly but I don't see any data collected.
    One thing though, as you see in the attachment, varnish cache rate item is not supported.
