Zabbix and Powershell weirdness
  • Sponge
    • Mar 2016
    Hey,
    I am attempting to use Zabbix to query an MSSQL database and get the duration of the query (in miliseconds).
    It has mostly worked - I created a Powershell script that queries the database and outputs the duration, and put it on a host. I then created a Zabbix item for that host that activates the script every 30 seconds.
    The problem is, the values that I receive when Zabbix runs the scripts are different than the ones I get when running the script manually on the host!
    For example, when I run the script manually I get values like "9.0009" or "15.0015". But when Zabbix runs the script I get much higher values like "989.09". I really have no idea what is causing the difference, because the script should be running on the local host either way. I have a feeling this is a Zabbix issue and not a Powershell issue.
    This is the Powershell script:
    Write-Output "Starting check..." | Out-File -append c:\scripts\test.txt
    $StartTime = Get-Date
    Write-Output "Start Time: ${StartTime}" | Out-File -append c:\scripts\test.txt
    $Server = "SERVERNAME"
    $Username = 'USER'
    $Password = 'PASS'
    Write-Output "Invoking query" | Out-File -append c:\scripts\test.txt
    Invoke-SqlCmd -ServerInstance $Server -Query "select @@version" > $null -Username $Username -Password $Password
    $EndTime = Get-Date
    $Duration = New-TimeSpan -Start $StartTime -End $EndTime
    Write-Output "End Time: ${EndTime}" | Out-File -append c:\scripts\test.txt
    $Delta =  $Duration.TotalMilliseconds
    Write-Output "Delta: ${Delta}" | Out-File -append c:\scripts\test.txt
    Write-Output $Delta
    Note that, as you can see, it also saves the start time, end time and result in a txt file.
    This is the txt file:
    Starting check...
    Start Time: 05/30/2016 14:13:12
    Invoking query
    End Time: 05/30/2016 14:13:13
    Delta: 918.0918
    Starting check...
    Start Time: 05/30/2016 14:13:42
    Invoking query
    End Time: 05/30/2016 14:13:43
    Delta: 908.0881
    Starting check...
    Start Time: 05/30/2016 14:14:13
    Invoking query
    End Time: 05/30/2016 14:14:14
    Delta: 936.0936
    Starting check...
    Start Time: 05/30/2016 14:14:16
    Invoking query
    End Time: 05/30/2016 14:14:16
    Delta: 15.0015
    Starting check...
    Start Time: 05/30/2016 14:14:17
    Invoking query
    End Time: 05/30/2016 14:14:17
    Delta: 4.0004
    Starting check...
    Invoking query
    Delta: 6.0006
    Starting check...
    Invoking query
    Delta: 15.0015
    Those lower values are from when I ran the script manually. The high ones are from when Zabbix ran the script.
    I would appreciate any help regarding this issue.
    Thanks!
