Creating a Trigger for disk failure
  • flydude25
    • Apr 2023
    • 13
    So from what I gather(I am open to correction) that Zabbix does not have alerts for disk failure, only for storage utilization. I had an idea to use Windows event log and tie a trigger to Event id 52 to detect when a disk is failing. In need of direction and help! Most appreciated!
  • Hamardaban
    • May 2019
    • 2714
    S.M.A.R.T.
    • flydude25
      • Apr 2023
      • 13
      So I imported the template to get any changes that may have been made and I do not see the triggers. I even tried to import them manually and i get an expression error
      • solution
        • Jun 2020
        • 272
        remember to check if smartctl identifies your disk and collects data.
        cmd> smartctl.exe --scan
        cmd> smartctl.exe -A /dev/.. ***add as per previous step --scan
        if it does not collect data, then even with the template and plugin configured correctly, you will not have data/trigger in zabbix.​
        Wellington
