Simple Check items confuse
  • nmz
    • Jan 2016
    • 69
    I have two simple check items with net.tcp.service[http,IP,PORT] and net.tcp.service.perf[http,IP,PORT] My confuse is always get 0 in net.tcp.service.perf[http,IP,PORT]. Why always getting 0? net.tcp.service[http,IP,PORT] result is showing UP (1). Could someone explain to me why it's happening.
  • Atsushi
    • Aug 2013
    • 2028
    Please check data type for the item.
    Are you select 'Numeric (float)'?
    • nmz
      • Jan 2016
      • 69
      Nope, I set it as Type of information : Numeric (Unsigned) and Data type : Decimal
      • nmz
        • Jan 2016
        • 69
        Data type : Numeric(float) work as expected. Thanks
        • nmz
          • Jan 2016
          • 69
          According to the doc: sec - number of seconds spent while connecting to the service What should I set in Unit? Sec?
          • DmitryL
            • May 2016
            • 278
            Hello nmz,
            You can try set units as " s " .
            output should be something like "HH:MM:ss'
