Get process list 6.4
  • rapidiptxt
    • Apr 2023
    Glad to see that proc.get was added with the 6.4 release, but while the documentation highlights parameters, I am unable to find much of setting up a proper trigger. It also seemed that it this new key could have been added into a few templates by default such as the Windows by Zabbix Agent.
    I proceeded with creating the item manually to the template Windows by Zabbix Agent. I used the mode: summary, for the purpose of information needed in my use case.
    Performing a test against a host populates the information and is a trigger was made with the following:
    For the operational data I want to get the last 5 running processes. With this information I'd like to create a trigger action when the High Memory Utilization = 90% >5m also include the Process List.
    For testing I created a Trigger Action to only notify me of the Process List, but it seems even that does not have an event logged under Monitoring.
    Is anyone successfully using proc.get with a trigger action to report on processes? Based on my setup, does it appear right or did I miss something?
    • 4996
    If an item returns a json object, then what do think you get, if you make a trigger "last(/host/item)=0" ? Comparing oranges and apples? And following that, what do you think you get for {ITEM.LASTVALUE3} for example... (hint: it is not a 3rd process in your list)
    PS.. description of what is returned, is here https://www.zabbix.com/documentation...items/proc_get just a click away from https://www.zabbix.com/documentation...sercmdlinemode ...
