failed to process an incoming connection from x.x.x.x (TLS encryption)
  • CRSTLLV
    • May 2019
    • 16
    Facing a strange problem. passive zabbix agents getting constant connection problems when used TLS PSK encryption. When disabling TLS, no problems.
    Errors in the log:
    2023/04/17 10:27:21.499767 failed to process an incoming connection from x.x.x.x : 40C67F32ED7F0000:error:0A0000FD:SSL routines:tls_psk_do_binder:binder does not verify:../ssl/statem/extensions.c:1612:
    2023/04/17 10:27:36.567475 failed to process an incoming connection from x.x.x.x: 40C67F32ED7F0000:error:0A0000FD:SSL routines:tls_psk_do_binder:binder does not verify:../ssl/statem/extensions.c:1612:
    192908:20230417:072451.855 Zabbix agent item "vfs.fs.size[/,used]" on host “xxxxxxx” failed: first network error, wait for 15 seconds
    192914:20230417:072506.721 Zabbix agent item "vfs.fs.size[/var/snap/firefox/common/host-hunspell,used]" on host "xxxxxxx" failed: another network error, wait for 15 seconds
    192914:20230417:072521.786 Zabbix agent item "vm.memory.size[total]" on host "xxxxxxx" failed: another network error, wait for 15 seconds
    192914:20230417:072536.851 temporarily disabling Zabbix agent checks on host "xxxxxxx": interface unavailable
    any ideas how to solve it?
Name:	Screen Shot 2023-04-17 at 10.33.56.png
