High Preprocessing Manager Queue in Zabbix Proxies and Data collection issue
  • Toolsadmin
    • Apr 2023
    Hi All,
    We are having Zabbix 6.0.2 environment with
    • Two HA Zabbix servers
    • Primary and Secondary MySQL 8.0.26 (1TB storage)
    • 10 Zabbix proxies ( Active proxies)
    • 1957 Hosts (1796 enabled/ 161 disabled) onboarded and 5000 hosts yet to be onboarded
    • Number of items - 93387 enabled/ 147975 disabled/ 2575 not supported
    • Number of triggers - 40542
    • Required server performance, new values per second - 416.5
    ​Click image for larger version  Name:	image.png Views:	15 Size:	55.7 KB ID:	463125
    Two of our Zabbix proxies are having High queue, and data collection is stopped because of that. As a part of troubleshooting we have found that Zabbix proxy was unable to preprocess the item values which is resulting in high preprocessing manager queue as attached in the screenshots.
    Zabbix proxy configuration is same for all the proxy servers still only two proxy servers are having the issue, We have followed every possible ways of troubleshooting still no luck in resolving the issue. MySQL DB configuration and fine tuning has also been done according to suggestions made.
    Click image for larger version  Name:	dataurl556704.png Views:	9 Size:	5.3 KB ID:	463126
    ​Click image for larger version  Name:	image.png Views:	8 Size:	189.6 KB ID:	463127
    Click image for larger version  Name:	image.png Views:	9 Size:	228.7 KB ID:	463128
    Zabbix Proxy Configuration:
    ProxyLocalBuffer=1
    ProxyOfflineBuffer=4
    HeartbeatFrequency=120
    ConfigFrequency=3600
    DataSenderFrequency=120
    StartPollers=5
    StartIPMIPollers=1
    StartPreprocessors=5
    StartPollersUnreachable=10
    StartHistoryPollers=2
    StartTrappers=10
    StartPingers=1
    StartDiscoverers=1
    StartHTTPPollers=1
    HousekeepingFrequency=6
    CacheSize=2G
    StartDBSyncers=4
    HistoryCacheSize=512M
    HistoryIndexCacheSize=512M
    Timeout=15
    TrapperTimeout=300
    UnreachablePeriod=300
    UnavailableDelay=300
    UnreachableDelay=120
    LogSlowQueries=10000
    StatsAllowedIP=127.0.0.1
    ListenBacklog=300
    MySQL Proxy DB Configuration:
    #GLOBAL BUFFERS
    innodb_buffer_pool_size =16G
    innodb_log_file_size =1G
    innodb_log_buffer_size =256M
    innodb_flush_log_at_trx_commit = 2
    innodb_lock_wait_timeout = 50
    innodb_thread_concurrency=12
    innodb_file_per_table=1
    innodb_log_files_in_group=2
    # Session Buffers
    sort_buffer_size =16M
    join_buffer_size=16M
    net_buffer_length = 1M
    read_buffer_size =16M
    read_rnd_buffer_size =64M
    myisam_sort_buffer_size = 128M
    # General Variables
    back_log = 200
    long_query_time=1
    innodb_flush_method=O_DIRECT
    thread_cache_size =256
    delayed_queue_size = 1500
    max_connections = 6500
    max_connect_errors = 99999
    max_allowed_packet=1024M
    tmp_table_size=64M
    concurrent_insert=1
    log_bin_trust_function_creators=1
    group_concat_max_len=4294967295
    open_files_limit=10000
    Zabbix Server Configuration:
    AllowUnsupportedDBVersions=1
    HistoryStorageTypes=uint,dbl,str,log,text
    HistoryStorageDateIndex=1
    ExportDir=/h
    ExportFileSize=1G
    ExportType=events,history,trends
    ############ ADVANCED PARAMETERS ################
    StartPollers=150
    StartIPMIPollers=1
    StartPreprocessors=75
    StartPollersUnreachable=50
    StartHistoryPollers=100
    StartTrappers=200
    StartPingers=25
    StartDiscoverers=2
    StartHTTPPollers=1
    StartTimers=10
    StartEscalators=25
    StartAlerters=35
    HousekeepingFrequency=4
    MaxHousekeeperDelete=50000
    CacheSize=12G
    CacheUpdateFrequency=300
    StartDBSyncers=10
    HistoryCacheSize=1G
    HistoryIndexCacheSize=1G
    TrendCacheSize=1G
    TrendFunctionCacheSize=1G
    ValueCacheSize=8G
    Timeout=30
    TrapperTimeout=120
    UnreachablePeriod=120
    UnavailableDelay=60
    UnreachableDelay=60
    TmpDir=/tmp
    StartLLDProcessors=25
    StatsAllowedIP=::/0
    ServiceManagerSyncFrequency=300
    ProblemHousekeepingFrequency=900
    ListenBacklog=3000
    Because of high queue on proxies, data collection has stopped completely, Can anyone please help us in resolving this issue?
    blogs referred:
    https://blog.zabbix.com/how-to-troub...h-queue/12244​
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    Upgrade to the latest 6.0.x version. The fixes that deal with slow preprocessing were introduced around 6.0.11/6.0.12.
    • Hamardaban
      Hamardaban commented
      Avoid the 6.0.15
