Unable to install Zabbix server, front end and agent (6.0 LTS and 6.4)
  • ShadowoftheDarkgod
    • May 2020
    I'm trying to setup a Zabbix server (Centos Stream 9) and I can't seem to install the Zabbix server, front end and agent for both 6.0 LTS and 6.4 as I keep getting this error for 2 days now
     Problem: package zabbix-web-deps-6.0.16-release1.el9.noarch requires zabbix-web = 6.0.16-release1.el9, but none of the providers can be installed
      - cannot install both zabbix-web-6.0.16-release1.el9.noarch and zabbix-web-1:6.0.16-1.el9.noarch
      - package zabbix-apache-conf-6.0.16-release1.el9.noarch requires zabbix-web-deps = 6.0.16-release1.el9, but none of the providers can be installed
      - package zabbix-web-mysql-1:6.0.16-1.el9.noarch requires zabbix-web = 1:6.0.16-1.el9, but none of the providers can be installed
      - cannot install the best candidate for the job
    (try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)​
    Is there an ongoing Zabbix maintenance that's going on right now? Should I go to the skip broken option?
  • tim.mooney
    • Dec 2012
    • 1430
    You don't need '--skip-broken'. It looks like you're mixing packages from two different sources. I say that based on the "cannot install both" line, which seems to be implying there would be two different versions of the 'zabbix-web' package involved.
    Check your system to make certain you don't already have any 'zabbix*' packages installed.​
      • May 2020
      Newly created VM and checked the list no installed zabbix-web packages.
      It seems I keep getting stopped at the zabbix-web installation with the none of the provider can be installed
