SMART
  • hpxw
    • Apr 2023
    SMART
    I've added this template to a server, but i'm always get [m|ZBX_NOTSUPPORTED] [Unsupported item key.]
    smartmontools are installed and sudo visudo
    zabbix ALL=(ALL) NOPASSWD:/usr/sbin/smartctl
    tried to test from zabbix server
    zabbix@zabbix:~$ zabbix_get -s x.x.x.x -p 10050 -k smart.disk.descovery
    ZBX_NOTSUPPORTED: Unsupported item key.
    • 5004
    Did you install classic agent or agent 2? This smart thing works with agent2...
    • hpxw
      • Apr 2023
      that was my fault... After installing agent 2 it works fine. Thanks!
      #closed
