How to transfer zabbix dump in Mysql to postgres base
  • nom77
    • Mar 2017
    • 34
    Ideally I should convert the dump file to postgres format.
    Or is it possible to save all zabbix data through the web admin and then transfer it to the postgres base.
    Is there a way ?​
    • 5004
    You cannot export data from GUI.
    Its not really a Zabbix question.. just do some googling on the topic... you get a lot of info...
    There are converters available https://github.com/dimitri/pgloader for example, there are others...
