Trigger for Eventlog, Severity query
  • sined
    • Apr 2023
    Hello
    Not really a problem, but rather a big board in front of my head.
    I am trying to monitor an event log. (Veeam).
    Under the log "Veeam Backup" I find everything I need under ID 0. I have a separate item for each job, which then looks like this:
    eventlog[Veeam Backup,.*VM.*,,Veeam Backup,0,,all]
    Thus, the above-mentioned item history contains, for example, the following:
    Timestamp Local time Source Severity Event ID Value
    2023-04-25 08:21:13 2023-04-25 08:20:22 Veeam Backup Error 0
    Session HQ VM's (Incremental) has been completed.
    2023-04-25 00:22:03 2023-04-25 00:21:49 Veeam Backup Information 0
    The text always says that it has been completed, and under Severity whether it went wrong "Error" or worked "information".
    How can I build a trigger now? I thought of something like:
    If the last log entry is Severity = Error, then a message is displayed until the last log entry is Severity <> Error.
    Or do you have another idea?
    I have tested the existing Veeam templates, but they do not work with my setup (S2D server).
    Translated with www.DeepL.com/Translator (free version)​
  • Answer selected by sined at 26-04-2023, 10:45.
    cyber
    • 5004
    logseverity is the function you may try.
    logseverity (/host/key,<#num<:time shift>>)
    Log severity of the last log entry. See common parameters.
    #num (optional) - the Nth most recent value
    Supported value types: log
    Returns:
    0 - default severity
    N - severity (integer, useful for Windows event logs: 1 - Information, 2 - Warning, 4 - Error, 7 - Failure Audit, 8 - Success Audit, 9 - Critical, 10 - Verbose).
    Zabbix takes log severity from Information field of Windows event log.
      • 5004
      Returns:
      • sined
        • Apr 2023
        Thanks Cyber, this is what I was looking for!
