Zabbix behind Nginx and CloudFlare - TypeError: Template is not a constructor
  • saloricardo
    • Dec 2021
    Hello everyone, all right?
    Next, I have a test/study environment in Docker. I'm using the latest version of 6.0.
    My environment runs on a Docker, as I mentioned earlier, I have an Nginx Proxy Manager and Authelia for authentication, in addition to everything behind CloudFlare as well.
    I've already removed Authelia's authentication, but according to my tests, the problem is with the reverse proxy, but I can't get the settings right and I don't know what else to do.
    Some Zabbix menus just don't load, like the image below.
    Has anyone ever experienced this? Do you know how to solve?
    Thanks for the help!
  • codename_sasha
    • Jan 2023
    Hi, same problem here with latest 6.4.2, using Cloudflare tunnel. Unfortunately no progress so far... Someone suggested disabling chunked encoding on Cloudflare, but didn't help.
    • saloricardo
      • Dec 2021
      Hello, does anyone know how to solve this situation?
      • seanbatt
        • May 2023
        I am testing Zabbix v6.0.16 behind Cloudflare, too.
        I have several similar, show stopping issues where javascript throws errors like "Uncaught ReferenceError: Cannot access 'CWidget' before initialization" and "Uncaught ReferenceError: CDashboard is not defined".
        From what I can see of the javascript read in via jsLoader.php, it seems fine (but I am not knowledgable with javascript).
        Thanks to this thread, I have further ideas to try, e.g.comparing 6.0.16 in my home lab and comparing the concatenated js output from jsLoader.php.
        What the fix might be remains to be seen.
        Best wishes, Sean​
        • codename_sasha
          • Jan 2023
          Hi, disabling rocket loader solved my issue. I made a configuration rule to disable it for individual hostnames and it helped.
          • saloricardo
            • Dec 2021
            Hi codename_sasha, thanks a lot for your help! I disabled the rocket loader and everything just went back to working perfectly. Maybe later I'll study about it, because I saw that it's possible to control the rocker loader through the headers.
            Again, thank you very much!​
            • seanbatt
              • May 2023
              For my problem with javascript, I was hoping this would be the issue, but we checked and Rocket Loader was not enabled. I've run jsLoader.php outside the Cloudflare environment and can see that the js returned is different: the individual js files are returned in a different order. That sort of change seemed a bit gross to be changed by Rocket Loader.
              • saloricardo
                • Dec 2021
                seanbatt, but did you manage to solve the problem or are you still with it?
                • seanbatt
                  • May 2023
                  Still have the problem, saloricardo .
                  • saloricardo
                    • Dec 2021
                    seanbatt, sorry for the long time to reply.
                    You use Nginx reverse proxy?
                    In addition to the CloudFlare configuration, I also added some settings in nginx for Zabbix access.
                    location / {
                        proxy_set_header X-Real-IP $remote_addr;
                        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                        proxy_cookie_path / zabbix.domain.com;
                    ps: Attention to the address in proxy_cookie_path.​
