Help send email
  • mcanelada
    • Jun 2016
    • 15
    Help send email
    Good morning everyone ,
    I'm trying to send alert e-mail through the Zabbix however unsuccessfully , this error appears to me
    /usr/lib/zabbix/alertscripts/zabbix-sendemail: [2] No such file or directory
    How can i fix this ?
  • zabx_ks
    • May 2016
    • 48
    Hi mcanelada,
    Looks like you are using media type "script" not "email".
    Please show screenshot of your User profile - media
    p.s
    More about how to use Custom alertscripts:
    And more about how to use e-mail notifications:
    zabx_ks
    • mcanelada
      • Jun 2016
      • 15
      Follow the img
Name:	Captura de tela de 2016-06-09 11:17:15.png
      • zabx_ks
        • May 2016
        • 48
        mcanelada,
        Type should be "e-mail"
        zabx_ks
        • mcanelada
          • Jun 2016
          • 15
          But i Use an script
          Its right ? Or i need change to email to ?
          • zabx_ks
            • May 2016
            • 48
            But i Use an script
            Can you please give me more detailed info about what you are planing to do in this case?
            p.s.
            based on:
            Have you put your "zabbix-sendemail" script file in /usr/lib/zabbix/alertscripts/ directory?
            zabx_ks
            • mcanelada
              • Jun 2016
              • 15
              I would like to use the snmp actions where is the part that shows me the% of free space on the server's disks and according to the level sending email with this alert .
              I checked and the file are on this folder
              • zabx_ks
                • May 2016
                • 48
                mcanelada,
                I hope I understand you correctly...
                To do that, there are 3 steps:
                1) make snmp item
                2) make trigger
                3) make email notification
                have you made at least 1st and 2nd step?
                p.s.
                Check if zabbix user have permissions to execute that file:
                ls -lah /usr/lib/zabbix/alertscripts/
                zabx_ks
                • mcanelada
                  • Jun 2016
                  • 15
                  Good morning ,
                  I made the first and third step further did not understand how the part to assemble trigger
                  • zabx_ks
                    • May 2016
                    • 48
                    Hello mcanelada,
                    Please show me a screenshot of your item configuration.
                    zabx_ks
                    • mcanelada
                      • Jun 2016
                      • 15
                      This item ?
                      • zabx_ks
                        • May 2016
                        • 48
                        mcanelada,
                        No, this is a "action".
                        I mean Configuration - hosts - "your host" - item.
                        That item which you are using at step " 1) make snmp item"
                        example my item:
                        zabx_ks
                        • mcanelada
                          • Jun 2016
                          • 15
                          I got this
                          • zabx_ks
                            • May 2016
                            • 48
                            Dear mcanelad
                            Overall my recommendation to you would be:
                            1) install zabbix agent on that host which you want to monitor.
                            2) then add it as new host in frontend
                            3) make item for that host which shows free disk space (example like in my screenshot)
                            4) then you will be able to make trigger which fires alert when your disk space is lower than example ~10% or whatever how much %
                            5) and in the end you will be able to configure action with mail notification which would send you a e-mail if trigger will fire.
                            zabx_ks
                            • mcanelada
                              • Jun 2016
                              • 15
                              #15
                              Hey zabx_ks,
                              One last question,
                              How i make triggers can u help me on this task ?
                              BR
