Hi
Have to start with telling you that I´m new to Zabbix
I have installed Ubuntu 14.0.4 LTS and Zabbix 3.0 from packages following this guide: https://www.zabbix.com/documentation..._from_packages
and https://www.zabbix.com/documentation...all/db_scripts
My problem is that I can´t find the scripts that I´m supposed to import (i.e. schema.sql, images.sql and data.sql) I have searched with "find / -name 'schema.sql' " and so on...
The database is up and running with user zabbix setup, and there are some data in the 113 tables but I have no idea whether I miss something or not.
Are they a dealbreaker to get my server up and running or can I continue without them? Are they available for download somewhere?
Regards
Magnus
Regards
Magnus
