Upgrade Zabbix Proxy 6.2 -> 6.4 undefined symbol: usmAES192PrivProtocol
  • pc-nico
    • May 2014
    • 29
    Hey
    Env:
    Suse SELS 15
    Runing Zabbix Proxy: zabbix-proxy-mysql-6.2.9-release1.sles15.x86_64.rpm
    After Upgrade via Repo to zabbix-proxy-mysql-6.4.2-release1.sles15.x86_64.rpm the Service won´t start.
    When i try a simple zabbix_proxy -V I got this Error Message:
    Hostname:~ # zabbix_proxy
    zabbix_proxy: symbol lookup error: zabbix_proxy: undefined symbol: usmAES192PrivProtocol​
    Any Idea?
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    Please see if this is the same case with Suse.
    • pc-nico
      • May 2014
      • 29
      Looks like there is a newer Version installed:
      zypper se -s net-snmp
      Loading repository data...
      Reading installed packages...
      S | Name | Type | Version | Arch | Repository
      i | net-snmp | package | 5.9.3-150300.15.3.1 | x86_64 | san_sles_15.3-prod-SLE-Module-Basesystem15-SP3-Updates for x86_64
      v | net-snmp | package | 5.7.3-10.12.1 | x86_64 | san_sles_15.3-prod-SLE-Module-Basesystem15-SP3-Updates for x86_64
      v | net-snmp | package | 5.7.3-10.9.1 | x86_64 | san_sles_15.3-prod-SLE-Module-Basesystem15-SP3-Updates for x86_64
      v | net-snmp | package | 5.7.3-8.24 | x86_64 | san_sles_15.3-prod-SLE-Module-Basesystem15-SP3-Pool for x86_64
      • pc-nico
        • May 2014
        • 29
        no one with the same problem?
        • james.cook000@gmail.com
          • Apr 2018
          • 49
          Yes I have the same problem when upgrading to Zabbix 6.4.22:
          i | net-snmp | package | 5.9.3-150300.15.3.1 | x86_64 | replica-SLE-Module-Basesystem15-SP3-Updates for x86_64
          Oct 17 13:42:01 nswlnxvm236 zabbix_server[5398]: /usr/sbin/zabbix_server: symbol lookup error: /usr/sbin/zabbix_server: undefined symbol: usmAES192PrivProtocol
          I will note that i have net-snmp-devel installed and there is no net-snmp-libs as per the centos issue, however I believe libsnmp40 (5.9.3-150300.15.3.1) is the equivelent.
            • Apr 2018
            • 49
            I compiled the zabbix server on the local host and it ran fine, I have raised issue https://support.zabbix.com/browse/ZBX-23556
            • pc-nico
              • May 2014
              • 29
              My goal to get it running, was Update zu SLES Patchlevel 15-SP4
                • Apr 2018
                • 49
                They have updated the issuue and looks like they are sorting it in 6.0.23....
                I just compiled as a work around...
