mariadb zabbix table is missing
  • majed17
    • Oct 2019
    • 21
    Peace, after zabbix database grew and hogged all the space on the server i deleted the 2 largest tables, history and trends
    now in the problems page i get :
    <output class="msg-bad" role="contentinfo" aria-label="Error message"><div class="msg-details"><ul class="list-dashed"><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='43547' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='43695' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='44007' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='44985' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='47341' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='51690' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li><li>Error in query [SELECT MAX(h.clock) FROM history_uint h WHERE h.itemid='63466' AND h.clock&gt;1684674338] [Table 'zabbix.history_uint' doesn't exist] [zabbix.php:22 → require_once() → ZBase-&gt;run() → ZBase-&gt;processRequest() → ZBase-&gt;processResponseFinal() → CView-&gt;getOutput() → include() → CPartial-&gt;getOutput() → include() → CScreenProblem-&gt;get() → getTriggerDependencies() → CMacrosResolverHelper::resolveTriggerNames() → CMacrosResolver-&gt;resolveTriggerNames() → CMacrosResolverGeneral-&gt;getItemMacros() → CHistoryManager-&gt;getLastValues() → CHistoryManager-&gt;getLastValuesFromSql() → DBselect() → trigger_error() in include/db.inc.php:248]</li></ul></div><button type="button" class="overlay-close-btn" onclick="jQuery(this).closest('.msg-bad').remove();" title="Close"></button></output>​
  • tim.mooney
    • Dec 2012
    • 1436
    Well, you know what you did that broke it, I'm not sure why you're posting here about it? Are you planning to fix it?
    Have you told your supervisor that deleting two tables was your solution to the space issue?
    • majed17
      • Oct 2019
      • 21
      well i don't know how to fix it, so i came here for help.
        • 4996
        Oh deer, oh deer... This is so wrong on so many levels...
        Your topic name says what's wrong, you stated in first sentence, what you did to get to that point... So press ctrl-z (figuratively speaking) until you get it fixed...
        • LenR
          • Sep 2009
          • 1011
          In the Zabbix install doc is a step to build the initial database. You are at the crossroads of "start over" and "restore from backup".
          • majed17
            • Oct 2019
            • 21
            can't i just configure the tables again and it works?
              • 4996
              From that point on, it probably will work, but you may experience some errors if something happens to refer the data you deleted... If its OK with you, then its better than not working instance.
              • majed17
                • Oct 2019
                • 21
                so how to recreate the tables?
