Exclude Link down notifications
  • sbdcunha
    • May 2023
    • 27
    Dear All,
    I have recently installed zabbix 6.4 and its working fine
    I am monitoring cisco 9300 access switches and would like to exclude link down / change speed email notifications and they flood my inbox.
    I did found information which states the ​user can redefine Context macro to value - 0 that marks ... No new trigger will be fired if this interface is down
    But unable to find the place where i need to define this.
    I am using the default cisco IOS by snmp template.
    Appreciate your kind help
    Regards
    simon
    • 4996
    https://git.zabbix.com/projects/ZBX/...yaml#1099-1113
    I think you refer to this ?
    I think if you define a macro {$IFCONTROL:"{#IFNAME}} for the host, with a value 0 and replacing {#IFNAME} with the correct interface name, then it will work. As .. it will not fire that trigger.
    But if you still want to see the trigger but ignore the email, then you probably need to work out something with tags and ignore it on action execution level...
    • sbdcunha
      • May 2023
      • 27
      Dear Cyber,
      Thank you very much for your reply
      I do have a 48 port switch so do I need to define {#IFNAME}} for every interface
      can it be done globally for all interfaces
      apprecite your kind help
      regards
      simon
        • 4996
        Disable triggers... you can also modify discovery and set trigger prototypes to be "created disabled".
