zabbix-docker-zabbix-web-service crash on fresh install
  • jacolange
    • Jun 2023
    Docker version 24.0.2, build cb74dfc
    Please advice anyone ?
    See below log output
    root@zabbix:/zabbix-docker# docker-compose --profile full -f docker-compose_v3_centos_mysql_latest.yaml up
    [+] Building 0.0s (0/0)
    WARN[0000] Found orphan containers ([zabbix-docker-zabbix-build-mysql-1 zabbix-docker-zabbix-build-base-1]) for this project. If you removed or renamed this service in your compose file, you can run this command with the --remove-orphans flag to clean it up.
    [+] Running 8/0
    ✔ Container zabbix-docker-db_data_mysql-1 Created 0.0s
    ✔ Container zabbix-docker-zabbix-java-gateway-1 Running 0.0s
    ✔ Container zabbix-docker-zabbix-snmptraps-1 Running 0.0s
    ✔ Container zabbix-docker-zabbix-web-service-1 Created 0.0s
    ✔ Container zabbix-docker-mysql-server-1 Running 0.0s
    ✔ Container zabbix-docker-zabbix-agent-1 Running 0.0s
    ✔ Container zabbix-docker-zabbix-server-1 Running 0.0s
    ✔ Container zabbix-docker-zabbix-web-nginx-mysql-1 Running 0.0s
    Attaching to zabbix-docker-db_data_mysql-1, zabbix-docker-mysql-server-1, zabbix-docker-zabbix-agent-1, zabbix-docker-zabbix-java-gateway-1, zabbix-docker-zabbix-server-1, zabbix-docker-zabbix-snmptraps-1, zabbix-docker-zabbix-web-nginx-mysql-1, zabbix-docker-zabbix-web-service-1
    zabbix-docker-zabbix-web-service-1 | ** Preparing Zabbix web service
    zabbix-docker-zabbix-web-service-1 | ** Preparing Zabbix web service configuration file
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "LogType": 'console'...updated
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "LogFile": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "LogFileSize": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "DebugLevel": '3'...updated
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "AllowedIP": 'zabbix-server'...updated
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "ListenPort": '10053'...updated
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "Timeout": '3'...updated
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "TLSAccept": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "TLSCAFile": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "TLSCertFile": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "TLSKeyFile": ''...removed
    zabbix-docker-zabbix-web-service-1 | ** Updating '/etc/zabbix/zabbix_web_service.conf' parameter "IgnoreURLCertErrors": ''...removed
    zabbix-docker-zabbix-web-service-1 | runtime/cgo: pthread_create failed: Operation not permitted
    zabbix-docker-zabbix-web-service-1 | SIGABRT: abort
    zabbix-docker-zabbix-web-service-1 | PC=0x7fedab22057c m=0 sigcode=18446744073709551610
    zabbix-docker-zabbix-web-service-1 | goroutine 0 [idle]:
    zabbix-docker-zabbix-web-service-1 | runtime: g 0: unknown pc 0x7fedab22057c
    zabbix-docker-zabbix-web-service-1 | stack: frame={sp:0x7ffd4c4781b0, fp:0x0} stack=[0x7ffd4bc79730,0x7ffd4c478740)
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4780b0: 0x0000000000000001 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4780c0: 0x00007fedab192e90 0x00007fedab230df0
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4780d0: 0x00007fed86200000 0x00007ffd4c478490
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4780e0: 0x00000000000000ff 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4780f0: 0x2525252525252525 0x2525252525252525
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478100: 0x000000ff00000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478110: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478120: 0x00000000000000ff 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478130: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478140: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478150: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478160: 0x000000000094d6b2 0x0000000000000006
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478170: 0x0000000000d795cb 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478180: 0x000000000094d69a 0x0000000000000006
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478190: 0x0000000000d795ca 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781a0: 0x000000000094ce62 0x00007fedab22056e
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781b0: <0x0000000000d795cc 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781c0: 0x000000000094d1fd 0x0000000000000005
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781d0: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781e0: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4781f0: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478200: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478210: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478220: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478230: 0x0000000000000000 0x0cf80ee46a3c9400
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478240: 0x00007fedab17c740 0x0000000000000006
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478250: 0x0000000000000001 0x00007ffd4c478580
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478260: 0x0000000000d48fe0 0x00007fedab1d3d46
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478270: 0x00007fedab37ae90 0x00007fedab1a77f3
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478280: 0x0000000000000020 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c478290: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | 0x00007ffd4c4782a0: 0x0000000000000000 0x0000000000000000
    zabbix-docker-zabbix-web-service-1 | goroutine 1 [running]:
    zabbix-docker-zabbix-web-service-1 | runtime.systemstack_switch()
    zabbix-docker-zabbix-web-service-1 | /usr/lib/golang/src/runtime/asm_amd64.s:459 fp=0xc000058780 sp=0xc000058778 pc=0x468a80
    zabbix-docker-zabbix-web-service-1 | runtime.main()
    zabbix-docker-zabbix-web-service-1 | /usr/lib/golang/src/runtime/proc.go:170 +0x6d fp=0xc0000587e0 sp=0xc000058780 pc=0x43cecd
    zabbix-docker-zabbix-web-service-1 | runtime.goexit()
    zabbix-docker-zabbix-web-service-1 | /usr/lib/golang/src/runtime/asm_amd64.s:1594 +0x1 fp=0xc0000587e8 sp=0xc0000587e0 pc=0x46aca1
    zabbix-docker-zabbix-web-service-1 | rax 0x0
    zabbix-docker-zabbix-web-service-1 | rbx 0x7fedab17c740
    zabbix-docker-zabbix-web-service-1 | rcx 0x7fedab22057c
    zabbix-docker-zabbix-web-service-1 | rdx 0x6
    zabbix-docker-zabbix-web-service-1 | rdi 0x1
    zabbix-docker-zabbix-web-service-1 | rsi 0x1
    zabbix-docker-zabbix-web-service-1 | rbp 0x1
    zabbix-docker-zabbix-web-service-1 | rsp 0x7ffd4c4781b0
    zabbix-docker-zabbix-web-service-1 | r8 0x7ffd4c478280
    zabbix-docker-zabbix-web-service-1 | r9 0x7fedab3304e0
    zabbix-docker-zabbix-web-service-1 | r10 0x8
    zabbix-docker-zabbix-web-service-1 | r11 0x246
    zabbix-docker-zabbix-web-service-1 | r12 0x6
    zabbix-docker-zabbix-web-service-1 | r13 0x7ffd4c478580
    zabbix-docker-zabbix-web-service-1 | r14 0xd48fe0
    zabbix-docker-zabbix-web-service-1 | r15 0x7fed83e0b35b
    zabbix-docker-zabbix-web-service-1 | rip 0x7fedab22057c
    zabbix-docker-zabbix-web-service-1 | rflags 0x246
    zabbix-docker-zabbix-web-service-1 | cs 0x33
    zabbix-docker-zabbix-web-service-1 | fs 0x0
    zabbix-docker-zabbix-web-service-1 | gs 0x0
    zabbix-docker-db_data_mysql-1 exited with code 0
    zabbix-docker-zabbix-web-service-1 exited with code 2
