Serring up agent via DDNS
  • funkytwig
    • Jun 2016
    • 37
    OK, so I have server and agent working on the server, now trying to set up a agent on a Rasbery Pi. It has agent 1.8.11 installed and the server is 3.0.3 but according to the documentation this should nor be a problem.
    I have port forwarded 10050 and 10051 for TCP & UDP on both the server computer and the Pi.
    Dont seems to be getting any errors relating to the Pi in server log since I restarted server and Disable/Enables the host but the graphs are empty. In Configuration->Hosts ZBX service is marked red. did have an error the host was unreachable a while ago before I set up the port forwarding but nothing recently.
    Hostname is correct in the agent config.
    Advice on what I may have done wrong work be great.
    Ben
