Zabbix 2.2 on rhel 7
  • pradhans0906
    • Jun 2016
    hello ,
    Am trying to install zabbix 2.2 version on RHEL 7 and am getting beow errors once i executed this .
    yum install zabbix-server-mysql zabbix-web-mysql
    --> Finished Dependency Resolution
    Error: Package: iksemel-1.4-2.el6.x86_64
    Requires: libgnutls.so.26(GNUTLS_1_4)(64bit)
    Error: Package: zabbix-server-mysql-2.4.6-1.el6.x86_64
    Requires: libnetsnmp.so.20()(64bit)
    Error: Package: zabbix-web-2.4.6-1.el6.noarch
    Requires: php-mbstring
    Requires: php-bcmath
    Requires: libgnutls.so.26()(64bit)
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    Dont know why exactly it's looking for the el6 ? can someone please put some light on it and provide some feedback.
  • Atsushi
    • Aug 2013
    • 2028
    Repository of setting is incorrect.
    Please use the repository of Zabbix 2.2 for RHEL 7.
    # yum remove zabbix-release
    # yum install http://repo.zabbix.com/zabbix/2.2/rhel/7/x86_64/zabbix-release-2.2-1.el7.noarch.rpm
    # yum clean all
    # yum install zabbix-server-mysql zabbix-web-mysql
    • pradhans0906
      • Jun 2016
      Thank you , the repo was point to old version , after fixing was able to continue with the installation .
      Thanks for your input .
