Monitoring proxy server
  • dach
    • Jan 2022
    • 16
    Hello.
    I'm using next versions of server, proxy and agent:
    zabbix_server (Zabbix) 6.2.7
    zabbix_proxy (Zabbix) 6.2.7
    zabbix_agent2 (Zabbix) 6.2.9
    Proxy installed in docker:
    Docker version 23.0.4, build f480fb1
    For this proxy, I've added template Template App Zabbix Proxy. There is the item Zabbix queue over 10 minutes with key zabbix[queue,10m].
    I expected that this item should check current queue only for this proxy. But this item gets general queue for all proxies and server:
    Is it a correct work for this item? Is there a way to monitoring queue only for one proxy?​
    • 4996
    If you test and select "get value from host" and "no proxy"... it means it will ask from server.., try to select a proxy there...
    If you assign this template to a proxy host and set it to be monitored by that same proxy, it will report you back values for this particular proxy...
    • dach
      • Jan 2022
      • 16
      I've already tried this way and had 0 in response to "get value and test":
        • 4996
        It does not match always... I do have a situation, that overview page shows for some proxies ~16k items in "more than 10minute" queue, but directly asked is 0. But for other proxies it shows same numbers... I have not bothered to look into this too much, I have trusted the directly asked item more than this overview page...
        • dach
          • Jan 2022
          • 16
          Ok, thank you. I'll try this way for a couple of days.
