Python API Modules not working with 6.4
  • michael.weber
    • Nov 2015
    • 121
    After Update to Zabbix Server 6.4 no Python Module is working. It does not matter if I am using token or username/password:
    pyzabbix.api.ZabbixAPIException: ('Error -32602: Invalid params., Not authorized.', -32602)
    Any idea?
    Already created a issue on most updated Python module, but no comment yet.
    Login not working - Error -32602: Invalid params., Not authorized.', -32602 · Issue users permissions problem · lukecyca/pyzabbix (github.com)​
  • chojin
    • Jul 2011
    • 64
    I'm seeing the same problem.
    After looking into the pyzabbix code; I see that they user the "Authorization: Bearer xxxx"-header method to authenticate.. As is documented in the Zabbix 6.4 API Documentation, noting that the "auth" parameter is deprecated in favor of the Authorization Bearer.
    So I tried manually both methods using curl..
    curl --request POST --url 'http://zabbixserver/api_jsonrpc.php' --header 'Authorization: Bearer 5488f5b22f4ec4d028596deecc90d41a7bd26076f818f2d3f5be9596ce1a5da9' --header 'Content-Type: application/json' --data '{"jsonrpc": "2.0","method": "host.get","params": {"output": ["hostid","host"]},"id": 2}'
    But I also get
    {"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"Not authorized."},"id":2}
    While
    curl --request POST --url 'http://zabbixserver/api_jsonrpc.php' --header 'Content-Type: application/json' --data '{"jsonrpc": "2.0","method": "host.get","params": {"output": ["hostid","host"]},"id": 2,"auth": "5488f5b22f4ec4d028596deecc90d41a7bd26076f818f2d3f5be9596ce1a5da9"}'
    correctly returns the desired result:
    {"jsonrpc":"2.0","result":[{"hostid":"14195","host":"icos"},{"hostid":"14207","host":"webdbprd"},{"hostid": ....
    So it looks to me that for some reason, despite the documentation claiming that we should now use the Authorization Bearer and "auth" being deprecated.. the bearer just doesn't work. (Above example is using an API token, but results are the same if I obtain a token using user.login method)​
    • chojin
      • Jul 2011
      • 64
      I opened a bug report at Zabbix for it: ZBX-22952 API authentication using Authorization bearer header does not work
      • michael.weber
        • Nov 2015
        • 121
        Thank you very much!
        • chojin
          • Jul 2011
          • 64
          I found adding
          SetEnvIf Authorization "(.*)" HTTP_AUTHORIZATION=$1
          ​to the apache config solved the problem.
          It seems Apache by default does not pass the Authorization header.
          • rons4
            • Jan 2020
            • 15
            I ran into the same issue with the Zabbix appliance and I found this solution here. I tried adding the above line to .conf files where I thought Apache would read them, unfortunately without any success. Can anyone please tell me there to find (or add) the Apache config file to add the mentioned line?
            Thanks a lot.
            • zabbix-user007
              • Jan 2025
              • 25
              Thanks a lot.
              was this ever answered for you? i am having the same issue
              • michael.weber
                • Nov 2015
                • 121
                I use the official python module https://blog.zabbix.com/python-zabbix-utils/27056/ now. This one is working without any modifications
                • zabbix-user007
                  • Jan 2025
                  • 25
                  thanks, Michael. I decided to create a new zabbix server and start from scratch or near scratch, anyway. the new server does not seem to have any issues connectig from CLI, although python would be fine, to..
                  cheers!
