Help needed to understand stacked graph (is it displaying incorrectly?)
  • leewp14
    • May 2023
    • 13
    Is it a problem with my understanding or the stacked graph is displaying incorrectly?
    Click image for larger version  Name:	image.png Views:	0 Size:	87.0 KB ID:	465808​
    The dark cyan color, which is at the top of the graph, if referred to at the bottom table, it shows that it is only 41C maximum, and the light cyan 53C maximum.
    But how come dark cyan is at the top of the graph? Did I understand it wrong?
    And there are so many at below 30C, which (again, per my understanding) is incorrect, as you can see from the bottom table, the minimum is at 34C
    Did I understand stacked graph wrongly? Can someone advice me on this?
    PS. The values of Y axis is also..... weird? they are in hundredths?
    I have cross checked the values, and also confirmed that the normal graph is correct (also, per my understanding).
    Click image for larger version  Name:	image.png Views:	0 Size:	93.6 KB ID:	465809​
    Thanks in advance.
    • 4996
    Don't you just misunderstand the concept of stacked graph?
    https://www.betterevaluation.org/met.../stacked-graph
    • leewp14
      • May 2023
      • 13
      You're right. Stacked graph is not suitable for my use case. Got it now, thanks again.
