Zabbix Agent Connection Timeout
  • Lemonfridge
    • Jun 2023
    The agent's host status is unknown. When checking the logs I get the following:
    8028:20230613:153921.022 In zbx_connect_to_server() [10.0.0.50]:10051 [timeout:3, connection timeout:3]
    8028:20230613:153921.024 In zbx_is_ip4() ip:'10.0.0.50'
    11452:20230613:153921.025 End of collect_perfstat() zz0.al3nrpxcbo9zz
    Zabbix host is installed in docker. Three different containers:
    zabbix/zabbix-server-mysql:alpine-6.4-latest 0.0.0.0:10051->10051/tcp, :::10051->10051/tcp zabbix-server-mysql
    zabbix/zabbix-web-nginx-mysql:alpine-6.4-latest 8443/tcp, 0.0.0.0:90->8080/tcp, :::90->8080/tcp zabbix-web-nginx-mysql
    zabbix/zabbix-java-gateway:alpine-6.4-latest 10052/tcp zabbix-java-gateway
    What I've done:
    Set the firewall rules correct to allow inbound traffic. Didnt work so I disabled the firewalls (Not production so it's fine).
    Agent config parameters changed:
    Hostname=AGENTSERVERIP4
    ServerActive= ZABBIXHOSTIP4
    Server= ZABBIXHOSTIP4
    LogRemoteCommands=1
    AllowKey=system.run[*] zz0.d2f3qnlr4tzz
    Then I maybe thought the reverse proxy on that server might be causing this, but this still happens when NGINX Proxy is turned off. So I don't think the proxy has an impact, it doesnt even listen to port 10051
    Anyone else knows what I can try next?
