Error with azure
  • RCG38
    • Jun 2023
    Error with azure
    I have configured everything correctly. I want to know how many credits a B4s series machine consumes and I get the error "unknown metric azure.vm.cpu.credits.remaining"
  • Atsushi
    • Aug 2013
    • 2028
    There is no key azure.vm.cpu.credits.remaining as an item key of type Zabbix agent. I think you probably referred to Template "Azure virtual machine by HTTP", but please check the contents of the template.
    Why don't you check it by using the template as it is?​
