cout trigger
  • Spirou
    • Jun 2016
    • 62
    cout trigger
    i want to count the number of "red" trigger, "orange" trigger etc..
    is it possible ? how to do that.
    best regards.
  • zabx_ks
    • May 2016
    • 48
    Hi Spirou,
    Which Zabbix version you have?
    There is option to see count of all active triggers in
     Monitoring -> trigger -> "set full screen"
    (This option is available only on 2.2 - 2.4 zabbix version)
    But if you want to see history count off all triggers then you can see it in
    Reports -> Triggers top 100
    . But it shows how many times number of status has changed for one trigger.
    Hope this information will be useful to you
    zabx_ks
    • Spirou
      • Jun 2016
      • 62
      ok ty,
      but i was mean count in another items like calculated items etc ?
      regards.
      • Spirou
        • Jun 2016
        • 62
        Bump ! ☺
        I found 'trigger.get' api and i want to know how to use it in zabbix ?
        Is it possible to create an item with this functiin and get the number
        Of my trigger with the different severity.
        Regards
        • Spirou
          • Jun 2016
          • 62
          BUMP !
          any idea guys how count number of trigger severity automaticly ?
          regards.
          • Spirou
            • Jun 2016
            • 62
            I found item type "Zabbix internal" but it count all trigger and i want count
            how many trigger are "information", "warning", "average" etc...
            if you have a tips ty
            • zabx_ks
              • May 2016
              • 48
              Hi Spirou,
              Not sure if it's officially supported on Zabbix.
              But I just made a quick google search and I found few community solutions which you might find useful:
              1) https://github.com/dav3860/zabbix_dashboard
              2) https://gist.github.com/chojayr/7401426
              3) https://github.com/tolleiv/dashing-zabbix
              You can try to test it but usage of such community resources is at your own risk.
              zabx_ks
              • Spirou
                • Jun 2016
                • 62
                Hi zabx_ks,
                ty
                i make an sql request :
                select count(*) from zabbix.triggers where priority=5 and value=1
                priority 5 for disaster, 4 for high etc...
                and value 1 when trigger is figher !
                end it seem working well
                regards.
                • Spirou
                  • Jun 2016
                  • 62
                  Originally posted by Spirou
                  Hi zabx_ks,
                  ty
                  regards.
                  Full request :
                  echo "select count(*) from zabbix.triggers where priority=5 and value=1;" | mysql -h localhost -uroot -pmysql | tail -1
