Connection from <host IP> rejected, allowed hosts: "<zabbix 6 servers>"
  • nickeshc
    • Apr 2023
    Hey all,
    I'm trying to connect a Zabbix agent running in Kubernetes, to a couple of active-passive external Zabbix 6 servers, but I'm not having any luck.
    The checks are passive only.
    From kubectl logs, I get this error message:
    2023/06/19 14:45:40.964412 failed to accept an incoming connection: connection from "172.31.72.130" rejected, allowed hosts: "zabbix-server,zabap1.man.company.lan,zabap2.brd.company.lan"
    From the Server, the status is Unknown:
    Here is a copy of my Helm zabbix_values.yaml, let me know if something isn't right here.
    ## nameOverride -- Override name of app
    nameOverride: ""
    ## fullnameOverride -- Override the full qualified app name
    fullnameOverride: ""
    ## kube-state-metrics.enabled -- If true, deploys the kube-state-metrics deployment
    kube-state-metrics:
      enabled: true
    ## Service accoun for Kubernetes API
    rbac:
      ## rbac.create  Specifies whether the RBAC resources should be created
      create: true
      additionalRulesForClusterRole: []
      ##  - apiGroups: [ "" ]
      ##    resources:
      ##      - nodes/proxy
      ##    verbs: [ "get", "list", "watch" ]
    serviceAccount:
      ## serviceAccount.create  Specifies whether a service account should be created
      create: true
      ## serviceAccount.name  The name of the service account to use. If not set name is generated using the fullname template
    ##  **Zabbix proxy** configurations
    zabbixProxy:
      ## Enables use of **Zabbix proxy**
      enabled: false
      containerSecurityContext: {}
      resources: {}
      image:
        ## Zabbix proxy Docker image name
        repository: zabbix/zabbix-proxy-sqlite3
        ## Tag of Docker image of Zabbix proxy
        tag: alpine-6.0.18
        pullPolicy: IfNotPresent
        ## List of dockerconfig secrets names to use when pulling images. Secrets must be manually created in the namespace.
        ## ref: https://kubernetes.io/docs/tasks/configure-pod-container/pull-image-private-registry/
        ##      https://kubernetes.io/docs/concepts/containers/images/#using-a-private-registry
        pullSecrets: []
      env:
        ## The variable allows to switch Zabbix proxy mode. By default, value is 0 - active proxy. Allowed values are 0 and 1.
        - name: ZBX_PROXYMODE
          value: 0
        ## Zabbix proxy hostname
        - name: ZBX_HOSTNAME
          value: zabbix-proxy
        ## Zabbix server host
        ## If ProxyMode is set to active mode:
        ## IP address or DNS name of Zabbix server to get configuration data from and send data to.
        ## If ProxyMode is set to passive mode:
        ## List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix server. Incoming connections will be accepted only from the addresses listed here. If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally and '::/0' will allow any IPv4 or IPv6 address. '0.0.0.0/0' can be used to allow any IPv4 address.
        ## Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
        ## Note that since version 6.0 the variable ZBX_SERVER_PORT is not supported anymore. Instead, add a colon (:) followed by the port number to the end of ZBX_SERVER_HOST value.
        - name: ZBX_SERVER_HOST
          value: "127.0.0.1"
        ## The variable is used to specify debug level. By default, value is 3
        - name: ZBX_DEBUGLEVEL
          value: 3
        ## Cache size
        - name: ZBX_CACHESIZE
          value: 128M
        ## The variable enable communication with Zabbix Java Gateway to collect Java related checks
        - name: ZBX_JAVAGATEWAY_ENABLE
          value: false
        ## How often proxy retrieves configuration data from Zabbix server in seconds. Active proxy parameter. Ignored for passive proxies.
        - name: ZBX_CONFIGFREQUENCY
          value: 60
        ## List can be extended with other environment variables listed here: https://github.com/zabbix/zabbix-docker/tree/6.0/Dockerfiles/proxy-sqlite3/alpine#other-variables
        ## For example:
        ## The variable is list of comma separated loadable Zabbix modules.
        ## - name: ZBX_LOADMODULE
        ##   value : dummy1.so,dummy2.so
      service:
        annotations: {}
        labels: {}
        ## Type of service for Zabbix proxy
        type: ClusterIP
        ## Port to expose service
        port: 10051
        ## Port of application pod
        targetPort: 10051
        ## Zabbix proxy Ingress externalIPs with optional path
        ## Ref: https://kubernetes.io/docs/user-guide/services/#external-ips
        ## Must be provided if ProxyMode is set to passive mode
        externalIPs: []
        ## Loadbalancer IP
        ## Only use if service.type is "LoadBalancer"
        loadBalancerIP: ""
        loadBalancerSourceRanges: []
      ## Node selector for Zabbix proxy
      nodeSelector: {}
      ## Tolerations configurations for Zabbix proxy
      tolerations: {}
      ## Affinity configurations for Zabbix proxy
      affinity: {}
      persistentVolume:
        ## If true, Zabbix proxy will create/use a Persistent Volume Claim
        enabled: false
        ## Zabbix proxy data Persistent Volume access modes
        ## Must match those of existing PV or dynamic provisioner
        ## Ref: http://kubernetes.io/docs/user-guide/persistent-volumes/
        accessModes:
          - ReadWriteOnce
        ## Zabbix proxy data Persistent Volume Claim annotations
        annotations: {}
        ## Zabbix proxy data Persistent Volume existing claim name
        ## Requires zabbixProxy.persistentVolume.enabled: true
        ## If defined, PVC must be created manually before volume will be bound
        existingClaim: ""
        ## Zabbix proxy data Persistent Volume mount root path
        mountPath: /data
        ## Zabbix proxy data Persistent Volume size
        ## Zabbix proxy data Persistent Volume Storage Class
        ## If defined, storageClassName: <storageClass>
        ## If set to "-", storageClassName: "", which disables dynamic provisioning
        ## If undefined (the default) or set to null, no storageClassName spec is
        ##   set, choosing the default provisioner.  (gp2 on AWS, standard on
        ##   GKE, AWS & OpenStack)
        storageClass: "-"
        ## Zabbix proxy data Persistent Volume Binding Mode
        ## If defined, volumeBindingMode: <volumeBindingMode>
        ## If undefined (the default) or set to null, no volumeBindingMode spec is
        ##   set, choosing the default mode.
        volumeBindingMode: ""
        ## Subdirectory of Zabbix proxy data Persistent Volume to mount
        ## Useful if the volume's root directory is not empty
        subPath: ""
    ## **Zabbix agent** configurations
    zabbixAgent:
      ## Enables use of Zabbix agent
      enabled: true
      resources: {}
          ##  requests:
          ##   cpu: 100m
          ##   memory: 54Mi
          ##  limits:
          ##   cpu: 100m
          ##   memory: 54Mi
      securityContext: {}
        # fsGroup: 65534
        # runAsGroup: 65534
        # runAsNonRoot: true
        # runAsUser: 65534
        ## capabilities:
        ##   add:
        ##   - SYS_TIME
      ## Expose the service to the host network
      hostNetwork: true
      # Specify dns configuration options for agent containers e.g ndots
      ## ref: https://kubernetes.io/docs/concepts/services-networking/dns-pod-service/#pod-dns-config
      dnsConfig: {}
      #  options:
      #  - name: ndots
      #    value: "1"
      ## Share the host process ID namespace
      hostPID: true
      ## If true, agent pods mounts host / at /host/root
      hostRootFsMount: true
      extraHostVolumeMounts: []
      ##  - name: <mountName>
      ##    hostPath: <hostPath>
      ##    mountPath: <mountPath>
      ##    readOnly: true|false
      ##    mountPropagation: None|HostToContainer|Bidirectional
      image:
        ## Zabbix agent Docker image name
        repository: zabbix/zabbix-agent2
        ## Tag of Docker image of Zabbix agent
        tag: alpine-6.0.18
        pullSecrets: []
      env:
        #- name: ZBX_SERVER_HOST
          #value: 0.0.0.0/0
          ## Zabbix server port
        - name: ZBX_SERVER_PORT
          value: 10051
          ## This variable is boolean (true or false) and enables or disables feature of passive checks. By default, value is true
        - name: ZBX_PASSIVE_ALLOW
          value: true
          ## This variable is boolean (true or false) and enables or disables feature of active checks
        - name: ZBX_ACTIVE_ALLOW
          value: false
          ## The variable is used to specify debug level, from 0 to 5
          value: 5
          ## The variable is used to specify timeout for processing checks. By default, value is 4.
        - name: ZBX_TIMEOUT
          value: 4
        ## List can be extended with other environment variables listed here: https://github.com/zabbix/zabbix-docker/tree/6.0/Dockerfiles/agent2/alpine#other-variables
        ## For example:
        ## The variable is comma separated list of allowed Zabbix server or proxy hosts for connections to Zabbix agent 2 container. You may specify port of Zabbix server or Zabbix proxy in such syntax: zabbix-server:10061,zabbix-proxy:10072
        ##  - name: ZBX_ACTIVESERVERS
        ##    value: zabap1.man.company.lan,zabap2.brd.company.lan
        - name: ZBX_PASSIVESERVERS
        ## The variable is list of comma separated loadable Zabbix modules. It works with volume /var/lib/zabbix/modules.
        ##   value: ''
      ## Node selector for Agent. Only supports Linux.
      nodeSelector:
        kubernetes.io/os: linux
      tolerations:
        - effect: NoSchedule
          key: node-role.kubernetes.io/control-plane
      affinity: {}
      serviceAccount:
        ## Specifies whether a ServiceAccount should be created
        create: true
        ## The name of the ServiceAccount to use.
        ## If not set and create is true, a name is generated using the fullname template
        annotations: {}
        imagePullSecrets: []
        automountServiceAccountToken: false
      service:
        type: ClusterIP
        port: 10050
        targetPort: 10050
        nodePort: 10050
        portName: zabbix-agent
        listenOnAllInterfaces: true
        annotations:
          agent.zabbix/monitor: "true"
      rbac:
        ## If true, create & use RBAC resources
        create: true
        ## If true, create & use Pod Security Policy resources
        ## https://kubernetes.io/docs/concepts/policy/pod-security-policy/
        ## PodSecurityPolicies disabled by default because they are deprecated in Kubernetes 1.21 and will be removed in Kubernetes 1.25.
        ## If you are using PodSecurityPolicies you can enable the previous behaviour by setting `rbac.pspEnabled: true`
        pspEnabled: false
        pspAnnotations: {}
  • vishal3108
    • Aug 2023
    hey..did you find any solution for it...i am also facing same problem.
    Zabbix Agents ( Passive) 6.0.4
    Zabbix Proxy (Active Mode)v6.0.4
    Zabbix Agent env-
    - env:
    valueFrom:
    fieldRef:
    apiVersion: v1
    fieldPath: spec.nodeName
    value: x.x.x.x
    - name: ZBX_SOURCEIP
    value: 0.0.0.0
    value: "10051"
    value: "5"
    - name: ZBX_TIMEOUT
    value: "10"
    value: "true"
    value: "false"
    image: zabbix/zabbix-agent2:alpine-6.0.4
    Zabbix Proxy env-
    - env:
    value: "0"
    value: 0.0.0.0
    value: abcd
    value: x.x.x.x:31011
    value: "5"
    value: 256M
    value: "false"
    value: "60"
    - name: ZBX_VALUECACHESIZE
    value: 128M
    image: zabbix/zabbix-proxy-sqlite3:alpine-6.0.4
    We have multiple servers on which zabbix agents are running as kubernetes daemonsets
    Zabbix agents (running as kubernetes daemonsets pods) are running but unable to accept incoming connections from zabbix proxy pod.
    2023/08/29 05:58:51.784103 starting manager
    2023/08/29 05:58:51.784287 [0] starting listener for '0.0.0.0:10050'
    2023/08/29 05:58:51.787962 listening for control connections on /tmp/agent.sock
    2023/08/29 05:59:05.488563 cannot accept incoming connection for peer: x.x.x.x
    2023/08/29 05:59:10.465123 cannot accept incoming connection for peer: x.x.x.x
    Above error is reporting in zabbix agent logs and x.x.x.x is particular node IP on which respective agent pod is running.
    All agent pods are giving same errors.
    Zabbix agent and proxy are on same kubernetes cluster, still it is not accepting incoming connection.
    Please advise.​
    • spostma73
      • Mar 2024
      That's coming from this one:
      kubectl edit daemonset zabbix-agent
      livenessProbe:
      failureThreshold: 3
      periodSeconds: 90
      successThreshold: 1
      tcpSocket:
      port: 10050
      timeoutSeconds: 3
      To double-check you can increase periodSeconds to I.E. 90 and the messages should come every 90 seconds
      • zohair.raza
        • Oct 2024
        anyone else looking for a solution:
        you can define network range in server settings under agent configuration
        Server=192.168.1.0/24,192.168.2.0/24
