Custum ITEN array result
  • grillotron
    • Aug 2022
    Hello everyone,
    I'm adding an ITEM to an existing template - specifically a wifi device. It is a mikrotik router using its CAPSMAN function.
    The idea is that it collects the MAC addresses of the devices connected to the Wi-Fi.
    I think I'm not using the correct object type that allows creating a record for each item returned.
    the OID call works:
    snmpwalk -v2c -c public 10.170.0.1 .1.3.6.1.4.1.14988.1.1.1.5.1.1
    MIKROTIK-MIB::mtxrWlCMRtabAddr.'*.MH)A'.22943 = STRING: 2a:17:4d:48:29:41
    MIKROTIK-MIB::mtxrWlCMRtabAddr.'p.P...'.22940 = STRING: 70:ee:50:19:f1:bc
    MIKROTIK-MIB::mtxrWlCMRtabAddr.'.i...*'.22941 = STRING: 84:69:93:d9:7f:2a
    MIKROTIK-MIB::mtxrWlCMRtabAddr.'...^..'.22942 = STRING: aa:f1:19:5e:fd:99​
    Please Can anyone guide me on how I should build it?
    Thank you so much​
