Server & Active Proxy Force TLS 1.3 PSK?
  • SANDMAN
    • Jun 2023
    • 14
    New to Zabbix in last week.
    I'm trying to force server + Active proxy to use TLS 1.3 PSK.
    Reviewing my Fortigate firewall it's using TLS 1.2
    I've reviewed and believe I have correct config? https://www.zabbix.com/documentation...ual/encryption
    Using docker
    zabbix/zabbix-server-pgsql:alpine-6.4-latest
    .env_srv
    ZBX_TLSCipherPSK13=TLS_CHACHA20_POLY1305_SHA256
    zabbix/zabbix-proxy-sqlite3:alpine-6.4-latest
    .env_prx
    ZBX_TLSCONNECT=psk
    Any ideas what I'm missing to get TLS 1.3 + CHACHA20_POLY1305_SHA256 ?
  • SANDMAN
    • Jun 2023
    • 14
    Review this more but still cannot get TLS 1.3 working.
    the .env_srv variable - ZBX_TLSCipherPSK13=TLS_CHACHA20_POLY1305_SHA256 - does not appear to be updating /etc/zabbix/zabbix_config.conf
    Upon container start
    zabbix-proxy-zabbix-proxy-sqlite3-1 | ** Updating '/etc/zabbix/zabbix_proxy.conf' parameter "TLSCipherPSK": ''...removed
    zabbix-proxy-zabbix-proxy-sqlite3-1 | ** Updating '/etc/zabbix/zabbix_proxy.conf' parameter "TLSCipherPSK13": ''...removed
    And reviewing the config its not set. However the other variables do work: ZBX_SERVER_HOST= , ZBX_TLSCONNECT=psk, ZBX_TLSPSKIDENTITY= , ZBX_TLSPSKFILE=​
    So then I tried creating own proxy config and doing a bind mount to overwrite config to force ZBX_TLSCipherPSK13=TLS_CHACHA20_POLY1305_SHA256 on both server + proxy configs. Still TLS 1.2.
    Test from docker proxy to docker host linux agent. tcp 10050 open.
    zabbix_get -s 192.168.20.5 -p 10050 --tls-connect psk --tls-psk-identity psk002 --tls-psk-file /tmp/psk.psk --tls-cipher13 TLS_CHACHA20_POLY1305_SHA256 -k "system.cpu.load[all,avg1]"
    zabbix_get [195]: Get value error: cannot connect to [[192.168.20.5]:10050]: [111] Connection refused​
    Now I'm going to replicate containers config and give ubuntu image a go. Alpine is difficult. I know the ubuntu has openssl OpenSSL 3.0.2
    I'd really like to get some TLS 1.3 proxies deployed.
    Any help greatly appreciated.
    • SANDMAN
      • Jun 2023
      • 14
      Dumb Fortigate and dumb me.
      After seeing a zabbix_sender test from proxy to server be successful with --tls-cipher13 TLS_CHACHA20_POLY1305_SHA256 I reviewed Fortigate and still only showed TLS 1.2 inbound.
      The server is behind Opnsense --> Fortigate (transparent mode) . Opnsense app detect with "zen armor" is poor so I review traffic on Fortigate.
      I then ran a packet capture on Opensense and reviewed with wireshark. Yup - proxy sending TLS 1.3.
      Lots of TLS 1.3 detected traffic flowing through Fortigate so through me off. Must not recognize PSK and needs cert to detect as TLS 1.3.
      • Markku
        • Sep 2018
        • 1788
        In the TLS hello message the version field is still 1.2 (0x0303) in TLS 1.3, the actual 1.3 is indicated in the "supported_versions" TLS extension field. Maybe Fortigate is just showing the version field and does not parse the full information?
        Markku
