TLS issue - Agent for FreeBSD v13.1 GnuTLS Zabbix Agent for FreeBSD v13.1 OpenSSL
  • judgewolf
    • Aug 2022
    Tested with Zabbix Agent for FreeBSD v 13.1 GnuTLS Zabbix Agent for FreeBSD v13.1 OpenSSL
    Packages were downloaded from https://www.zabbix.com/download_agen...&show_legacy=0
    Agent was not compiled or re-compiled from source code, and was used as is downloaded from the official download page
    Agents were tested of FreeNAS OpenBSD and a regular OpenBSD server without NAS Storage functionality
    The agent was able to start when all the TLS configurations were turned off and commented out from the zabbix_agent.conf file TLS Settings used:
    TLSConnect=psk TLSAccept=psk TLSPSKIdentity=example_identity TLSPSKFile=/usr/local/etc/zabbix.psk
    zabbix.psk chmod set to 644
    If the binary is started with the settings above is attempted it produces the following error:
    zabbix_agentd [1027]: "TLSConnect" configuration parameter cannot be used: Zabbix agent was compiled without TLS support zabbix_agentd [1027]: "TLSAccept" configuration parameter cannot be used: Zabbix agent was compiled without TLS support zabbix_agentd [1027]: "TLSPSKIdentity" configuration parameter cannot be used: Zabbix agent was compiled without TLS support zabbix_agentd [1027]: "TLSPSKFile" configuration parameter cannot be used: Zabbix agent was compiled without TLS support
