Hi
this discussion is still ongoing, I'm afraid (on AIX 5.3)
Years ago there was a problem with the command-line lenght
of the cmdline part in the /proc filesystem (limit was 80 chars).
Now the new fix is in place, but we don't get any value other than 0
for all existing process we would like to monitor:
The same result (0) is shown, if we do a zabbix_get for proc.num[/usr/sbin/inetd] or the zabbix_agentd itself.
Our old work-around using the user-parameters
work well.
Does somebody else see this behaviour with the 2.4.4 agent (or newer) or is it a bug in just this version ?
I found that the limit of MAXCOMLEN (32 chars.) is mentioned in
ZBX-5243 and the code in 3.0.3 looks like the proposed patch.
Thanks in advance for any answer.
Kind regards
Norbert.
$ /usr/sbin/zabbix_agentd -t proc.num[/usr/sbin/inetd] proc.num[/usr/sbin/inetd] [u|0] $ /usr/sbin/zabbix_agentd -t proc.num[,,run] proc.num[,,run] [u|0]
UserParameter=usr.proc.cntuser[*],ps -fu $1 | grep -c "$2" UserParameter=usr.proc.cnt[*],ps -eaf |grep -v grep|grep -c "$1"
Kind regards
Norbert.
