Sending a notification to a topic in a telegram group
  • Epigraphe
    • Jul 2023
    Good day.
    How to fix the script so that the telegram is sent not only to the group, but to the topic in this group?
    In fact, topics are responses to a message, so I need to add “reply_to_message_id” to the script so that the final URL looks like
    [URL]https://api.telegram.org/botToken/sendMessage?chat_id=-100xxxxx&reply_to_message_id=xxx&parse_mode=Markdown&text=[/URL]«Text»​
    Unfortunately, I don't understand Java so I can't do it myself.
    Can you please tell me how to add it?
    Script from the well-known media_telegram.yaml
    Thank you​
     script: |
    var Telegram = {
    token: null,
    to: null,
    message: null,
    proxy: null,
    parse_mode: null,
    escapeMarkup: function (str, mode) {
    switch (mode) {
    case 'markdown':
    return str.replace(/([_*\[`])/g, '\\$&');
    case 'markdownv2':
    return str.replace(/([_*\[\]()~`>#+\-=|{}.!])/g, '\\$&');
    default:
    return str;
    sendMessage: function () {
    var params = {
    chat_id: Telegram.to,
    text: Telegram.message,
    disable_web_page_preview: true,
    disable_notification: false
    data,
    response,
    request = new HttpRequest(),
    url = 'https://api.telegram.org/bot' + Telegram.token + '/sendMessage';
    if (Telegram.parse_mode !== null) {
    params['parse_mode'] = Telegram.parse_mode;
    if (Telegram.proxy) {
    request.setProxy(Telegram.proxy);
    request.addHeader('Content-Type: application/json');
    data = JSON.stringify(params);
    // Remove replace() function if you want to see the exposed token in the log file.
    Zabbix.log(4, '[Telegram Webhook] URL: ' + url.replace(Telegram.token, '<TOKEN>'));
    Zabbix.log(4, '[Telegram Webhook] params: ' + data);
    response = request.post(url, data);
    Zabbix.log(4, '[Telegram Webhook] HTTP code: ' + request.getStatus());
    try {
    response = JSON.parse(response);
    catch (error) {
    response = null;
    if (request.getStatus() !== 200 || typeof response.ok !== 'boolean' || response.ok !== true) {
    if (typeof response.description === 'string') {
    throw response.description;
    else {
    throw 'Unknown error. Check debug log for more information.';
    try {
    var params = JSON.parse(value);
    if (typeof params.Token === 'undefined') {
    throw 'Incorrect value is given for parameter "Token": parameter is missing';
    Telegram.token = params.Token;
    if (params.HTTPProxy) {
    Telegram.proxy = params.HTTPProxy;
    params.ParseMode = params.ParseMode.toLowerCase();
    if (['markdown', 'html', 'markdownv2'].indexOf(params.ParseMode) !== -1) {
    Telegram.parse_mode = params.ParseMode;
    Telegram.to = params.To;
    Telegram.message = params.Subject + '\n' + params.Message;
    if (['markdown', 'markdownv2'].indexOf(params.ParseMode) !== -1) {
    Telegram.message = Telegram.escapeMarkup(Telegram.message, params.ParseMode);
    Telegram.sendMessage();
    return 'OK';
    catch (error) {
    Zabbix.log(4, '[Telegram Webhook] notification failed: ' + error);
    throw 'Sending failed: ' + error + '.';
    timeout: 10s​
  • Epigraphe
    • Jul 2023
    We need to add just one line:
    reply_to_message_id: XXX,
    As a result, it will look like this:
    var params = {
    • kenanilgun
      • Feb 2024
      Originally posted by Epigraphe
      Good day.
      Thank you​
       script: |
      var Telegram = {
      token: null,
      to: null,
      message: null,
      proxy: null,
      parse_mode: null,
      switch (mode) {
      case 'markdown':
      case 'markdownv2':
      default:
      return str;
      var params = {
      data,
      response,
      try {
      catch (error) {
      response = null;
      else {
      try {
      return 'OK';
      catch (error) {
      timeout: 10s​
      Hello, you can use below code on script, It's working and tested.
      var Telegram = {
          token: null,
          to: null,
          message: null,
          proxy: null,
          threadId: null,
          parse_mode: null,
              switch (mode) {
                  case 'markdown':
                  case 'markdownv2':
                  default:
                      return str;
              var params = {
                  disable_notification: false,
                  message_thread_id: Telegram.threadId
              data,
              response,
              try {
              catch (error) {
                  response = null;
                  else {
      try {
          if (typeof params.ThreadId !== 'undefined') {
              Telegram.threadId = params.ThreadId;
          return 'OK';
      catch (error) {
      • cgood
        cgood commented
        Спасибо, работает. Для ситуации, когда надо отправлять в разные чаты и, соответственно, топики - пока нашел решение в прописывании message_thread_id в Inventory URL A (например) и задании параметра в media type Telegram ThreadId: {INVENTORY.URL.A}. Как сделать это в поле Send To: чтобы скрипт парсил и id и message_thread_id - не разобрался
