Filesystem discovery RegEx Problem
  • muelli
    • Jun 2021
    • 69
    Hello forum,
    I have a problem with a custom filesystem discovery RegEx.
    Filesystems are like this:
    1)
    /application/something/else
    2)
    /application/something/unwanted/else
    My regex so far is ^(application.+) which matches 1+2. But I do NOT want 2 to match.
    So far I could not find a regex that matches 1 but does NOT match 2.
    Does someone have a hint on a fitting regex?
    Thanks!
  • nuri
    • Jan 2015
    • 14
    Dear Zabbixian Friend,
    I am very new to REGEX.
    I have made a guess as of below;
    Hope this will help ....
    \/application(?!(\/something\/unwanted\/else))
    https://regex101.com/r/puCpMK/1
    Regards,
    Nuri.
    • muelli
      • Jun 2021
      • 69
      Thanks for the tip, actually the "something" part is dynamic as well :/
      more like this
      /application/XYZ/unwanted/other/parts
      where XYZ is 3 characters always.
      • nuri
        • Jan 2015
        • 14
        Try this >>> \/application(?!(\/\w{9}\/unwanted\/else))
        • nuri
          • Jan 2015
          • 14
          Or try that >>> \/application(?!(\/\w{3}\/unwanted\/else))​
          • muelli
            • Jun 2021
            • 69
            Hm, the first one does not match anything, the second one matches both....
            It is tricky....maybe this cannot be solved via regex at all.....
            I came up with this:
            ^\/application\/.{3}\/(?!(unwanted))
            This part: ^\/application\/.{3}\/
            should match /application/XYZ/
            now all I must figure out is to append something like a "AND NOT 'unwanted'"
            • nuri
              • Jan 2015
              • 14
              https://regex101.com/r/xjLW4y/1
              something >>> 9 characters.
              • muelli
                • Jun 2021
                • 69
                THats it, works in regex tester, now I will put it into zabbix!
                Thanks for your help!
                • nuri
                  • Jan 2015
                  • 14
                  Nice to hear you are happy with that.
