Zabbix 6.2 monitoring kubernetes 1.25 won't discover
  • brgsousa
    • Apr 2011
    I am using zabbix 6.2.4 on a standalone linux server and kubernetes 1.25.11 . Followed instructions at https://www.zabbix.com/integrations/kubernetes
    After applying "Kubernetes nodes by HTTP" template, discover rules worked fine.
    After applying "Kubernetes cluster state by HTTP" template, discover rules didn't work. I can't find any errors or something, even looking in kubernetes pods logs.
    How can I debug it better to find out what is happening?
  • Answer selected by brgsousa at 13-07-2023, 14:15.
    brgsousa
    • Apr 2011
    Since 6.2 version isn't available anymore as a helm chart, I fixed the problem by forcing the use of 6.2 images in the values.yaml for helm instalation.
    • brgsousa
      • Apr 2011
      Found this on /var/log/zabbix/zabbix_server.log :
      1124:20230712:162311.190 proxy "virtualserver-k8s-lab" protocol version 6.4 differs from server version 6.2
      1124:20230712:162311.190 cannot accept proxy data
      Will it work only with same version? I thought it would work because it specifies "6.2 and higher" at this page https://git.zabbix.com/projects/ZBX/...s%2Frelease%2F 6.2
      • brgsousa
        • Apr 2011
