PagerDuty Webhook test works but fails to show up in pagerduty
  • wmckay85
    • Dec 2022
    I followed this guide (PagerDuty monitoring and integration with Zabbix​) to set up the webhook, I test the media and it shows the test worked but it never appears in PagerDuty. Not sure where to go from here, I re-made the integration with a new API key just to check that, I modified the trigger action to be only "Not suppressed" and contains "Unavailable by ICMP Ping" but it still doesn't work.
    I did open a support ticket with PagerDuty since we pay for it but I figured I'd put the question here as well.
    Edit: Now with further testing I see the trigger is not processing PagerDuty at all, but it does the Jira part. I have the simplest conditions too:
    Click image for larger version  Name:	image.png Views:	1 Size:	15.8 KB ID:	467442​
    Click image for larger version  Name:	image.png Views:	1 Size:	29.1 KB ID:	467441
