TLS PSK Issue
  • CPT
    • Jul 2023
    TLS PSK Issue
    Sorry if this was answered elsewhere and I wasn't able to find it. I'm new to Zabbix and I'm trying to set up encryption for agent communications. I am creating a PSK as outlined in the Zabbix documentation, which appears to be just a normal openssl command. When I try to put the generated code into the Zabbix GUI, I am given the following error: "Incorrect value for field "tls_psk": an even number of hexadecimal characters is expected." Anyone know what I am doing wrong here? I am using the output from the command "openssl rand -hex 32​" as mentioned here https://www.zabbix.com/documentation...generating_psk . Thanks in advance.
  • solution
    • Jun 2020
    • 272
    It's simple
    in zabbix gui​, click in host --> Encryption
    Enable PSK
    PSK Indentity: key identify
    PSK: **Hexadecimal**
    Examble:
    Wellington
    • CPT
      • Jul 2023
      Hey Solution,
      Thank you for providing that info. Turns out I had typoed something when I was trying to set it up in the Zabbix GUI. I apprecaite the help though. I'm getting a new error when I try to start the agent on the server though. It's saying that connection type "unecrypte" is not allowed. I've updated the conf file for psk, so I'm not sure what I've missed.
      • solution
        • Jun 2020
        • 272
        You need to configure the agent to use PSK.
        Link:
        restart the agent after changing the conf.
        Wellington​​​​​​​
        • CPT
          • Jul 2023
          Thanks I got it working. I appeciate the help.
