Windows Zabbix Agent 2 vfs.dir.count ignores max_depth
  • Mr Snrub
    • Jul 2023
    Suspected bug in vfs.dir.count, specifically max_depth.
    Zabbix version 6.0.6
    Windows Zabbix Agent 2 version 6.4.0
    Proxy is used but I don't think it is relevant as I am setting up an active check.
    Item configured using the following key:
    vfs.dir.count["C:\\Temp\\Test",,,file,,0,,,,,]
    Parsed variables for readability:
    • dir = "C:\Temp\Test"
    • regex incl = null
    • regex excl = nul
    • types incl = file
    • types excl = null
    • max depth = 0 (no descending into subdirectories)
    • min size = null
    • max size = null
    • min age = null
    • max age = null
    • regex excl dir = null
    Expected behaviour is that only files explicitly in C:\Temp\Test should be counted as max_depth is 0.
    Actual behaviour is that files in sub-folders (2 levels deep) are also counted, as if max_depth is -1.
    max_depth tested using a value of 1 and that also counts incorrectly.
    regex_incl works as expected, I can filter on XML files and a test TXT file in the folder was not counted.
    Is this a known issue, or have I fudged up the parameters in some way?
