unknown metric mongodb.ping on MongoDB cluster by Zabbix agent 2 template.
  • MSG
    • Jul 2022
    • 14
    Hi All
    I would like to use template "MongoDB cluster by Zabbix agent 2" for monitoring MongoDB.
    I'm using ZABBIX 6.4.
    I put mongodb.conf to /etc/zabbix/zabbix_agent2.d/plugins.d
    https://git.zabbix.com/projects/AP/r...Frelease%2F6.4
    and set for Include=/etc/zabbix/zabbix_agent2.d/ on zabbix_agent2.conf.
    But ZABBIX Web console said "unknown metric monogodb.ping" and "unknown metric mongodb.service.status"
    Because mongodb.conf doesn't contains UserParameter so ZABBIX doesn't know what is monogodb.ping.
    Do you have any idea?
    Best regards.
    Michiteru
  • MSG
    • Jul 2022
    • 14
    resolved.
    I installed plugin from repo using rpm command.
    But it's not working because this is old version.
    So I remove this, and using yum command like below for install plugin for 6.4.
    $ sudo yum install zabbix-agent2-plugin-mongodb
    then It's working!!
