Zabbix 6.4 High CPU Usage
  • darkman
    • Jul 2023
    HTML Code:
    systemctl status zabbix-server
    ● zabbix-server.service - Zabbix Server
         Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
         Active: active (running) since Thu 2023-07-27 13:12:44 +0330; 8h ago
        Process: 2425 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
       Main PID: 2427 (zabbix_server)
          Tasks: 73 (limit: 11791)
         Memory: 919.5M
            CPU: 12h 1min 26.460s
         CGroup: /system.slice/zabbix-server.service
                 ├─ 2427 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
                 ├─ 2428 "/usr/sbin/zabbix_server: ha manager" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
                 ├─ 2429 "/usr/sbin/zabbix_server: service manager #1 [processed 0 events, updated 0 event tags, deleted 0 problems, synced 0 service upda
    tes, idle 4.014271 sec during 6.148183 sec]"
                 ├─ 2430 "/usr/sbin/zabbix_server: configuration syncer [synced configuration in 1.790388 sec, idle 10 sec]"
                 ├─ 2431 "/usr/sbin/zabbix_server: alert manager #1 [sent 0, failed 0 alerts, idle 5.316806 sec during 5.316991 sec]"
                 ├─ 2432 "/usr/sbin/zabbix_server: alerter #1 started" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
                 ├─ 2433 "/usr/sbin/zabbix_server: alerter #2 started" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
                 ├─ 2434 "/usr/sbin/zabbix_server: alerter #3 started" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
                 ├─ 2435 "/usr/sbin/zabbix_server: preprocessing manager #1 [queued 238, processed 15591 values, idle 4.856495 sec during 5.018052 sec]"
                 ├─ 2436 "/usr/sbin/zabbix_server: lld manager #1 [processed 3 LLD rules, idle 5.418797sec during 5.419011 sec]"
                 ├─ 2437 "/usr/sbin/zabbix_server: lld worker #1 [processed 4 LLD rules, idle 0.001669 sec during 5736.784227 sec]"
                 ├─ 2438 "/usr/sbin/zabbix_server: lld worker #2 [processed 5 LLD rules, idle 3.653103 sec during 5.920399 sec]"
                 ├─ 2439 "/usr/sbin/zabbix_server: housekeeper [deleted 525321 hist/trends, 0 items/triggers, 381 events, 0 sessions, 0 alarms, 0 audit it
    ems, 0 records in 1166.472034 sec, idle for 1 hour(s)]"
                 ├─ 2440 "/usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 events in 0.882370 sec, idle 58 sec]"
                 ├─ 2441 "/usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.000062 sec, idle 5 sec]"
                 ├─ 2442 "/usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000035 sec, idle 60 sec]"
                 ├─ 2443 "/usr/sbin/zabbix_server: history syncer #1 [processed 814 values, 703 triggers in 13.045717 sec, syncing history]"
                 ├─ 2444 "/usr/sbin/zabbix_server: history syncer #2 [processed 830 values, 529 triggers in 20.482057 sec, syncing history]"
                 ├─ 2445 "/usr/sbin/zabbix_server: history syncer #3 [processed 1669 values, 1459 triggers in 21.294807 sec, syncing history]"
                 ├─ 2447 "/usr/sbin/zabbix_server: history syncer #4 [processed 2424 values, 2447 triggers in 33.982536 sec, syncing history]"
                 ├─ 2450 "/usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0.002388 sec, idle 3 sec]"
                 ├─ 2454 "/usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 proxies in 0.000050 sec, idle 5 sec]"
                 ├─ 2455 "/usr/sbin/zabbix_server: self-monitoring [processed data in 0.000033 sec, idle 1 sec]"
                 ├─ 2456 "/usr/sbin/zabbix_server: task manager [processed 0 task(s) in 0.000717 sec, idle 5 sec]"
                 ├─ 2459 "/usr/sbin/zabbix_server: poller #1 [got 39 values in 5.662520 sec, getting values]"
                 ├─ 2461 "/usr/sbin/zabbix_server: poller #2 [got 133 values in 4.603291 sec, getting values]"
                 ├─ 2462 "/usr/sbin/zabbix_server: poller #3 [got 119 values in 5.710915 sec, getting values]"
                 ├─ 2463 "/usr/sbin/zabbix_server: poller #4 [got 206 values in 4.971214 sec, getting values]"
                 ├─ 2464 "/usr/sbin/zabbix_server: poller #5 [got 139 values in 5.201525 sec, getting values]"
                 ├─ 2465 "/usr/sbin/zabbix_server: unreachable poller #1 [got 1 values in 24.023779 sec, getting values]"
                 ├─ 2466 "/usr/sbin/zabbix_server: trapper #1 [processed data in 0.001781 sec, waiting for connection]"
                 ├─ 2467 "/usr/sbin/zabbix_server: trapper #2 [processed data in 0.241395 sec, waiting for connection]"
                 ├─ 2468 "/usr/sbin/zabbix_server: trapper #3 [processed data in 0.002179 sec, waiting for connection]"
                 ├─ 2469 "/usr/sbin/zabbix_server: trapper #4 [processed data in 0.001840 sec, waiting for connection]"
                 ├─ 2471 "/usr/sbin/zabbix_server: trapper #5 [processed data in 0.000171 sec, waiting for connection]"
                 ├─ 2472 "/usr/sbin/zabbix_server: trapper #6 [processed data in 0.000173 sec, waiting for connection]"
                 ├─ 2475 "/usr/sbin/zabbix_server: trapper #7 [processed data in 0.000203 sec, waiting for connection]"
                 ├─ 2479 "/usr/sbin/zabbix_server: trapper #8 [processed data in 0.000198 sec, waiting for connection]"
                 ├─ 2481 "/usr/sbin/zabbix_server: trapper #9 [processed data in 0.001909 sec, waiting for connection]"
                 ├─ 2482 "/usr/sbin/zabbix_server: trapper #10 [processed data in 0.001938 sec, waiting for connection]"
                 ├─ 2484 "/usr/sbin/zabbix_server: trapper #11 [processed data in 0.001871 sec, waiting for connection]"
                 ├─ 2487 "/usr/sbin/zabbix_server: trapper #12 [processed data in 0.002259 sec, waiting for connection]"
                 ├─ 2488 "/usr/sbin/zabbix_server: trapper #13 [processed data in 0.002218 sec, waiting for connection]"
                 ├─ 2490 "/usr/sbin/zabbix_server: trapper #14 [processed data in 0.001473 sec, waiting for connection]"
                 ├─ 2493 "/usr/sbin/zabbix_server: trapper #15 [processed data in 0.002683 sec, waiting for connection]"
                 ├─ 2494 "/usr/sbin/zabbix_server: icmp pinger #1 [got 0 values in 0.000051 sec, idle 1 sec]"
                 ├─ 2495 "/usr/sbin/zabbix_server: icmp pinger #2 [got 0 values in 0.000032 sec, idle 1 sec]"
                 ├─ 2497 "/usr/sbin/zabbix_server: icmp pinger #3 [got 0 values in 0.000058 sec, idle 1 sec]"
                 ├─ 2499 "/usr/sbin/zabbix_server: icmp pinger #4 [got 0 values in 0.000047 sec, idle 1 sec]"
                 ├─ 2501 "/usr/sbin/zabbix_server: icmp pinger #5 [got 0 values in 0.000049 sec, idle 1 sec]"
                 ├─ 2503 "/usr/sbin/zabbix_server: icmp pinger #6 [got 0 values in 0.000055 sec, idle 1 sec]"
                 ├─ 2504 "/usr/sbin/zabbix_server: icmp pinger #7 [pinging hosts]" "" ""
                 ├─ 2505 "/usr/sbin/zabbix_server: icmp pinger #8 [pinging hosts]" "" ""
                 ├─ 2506 "/usr/sbin/zabbix_server: icmp pinger #9 [pinging hosts]" "" ""
                 ├─ 2507 "/usr/sbin/zabbix_server: icmp pinger #10 [got 0 values in 0.000030 sec, idle 1 sec]"
                 ├─ 2508 "/usr/sbin/zabbix_server: alert syncer [queued 0 alerts(s), flushed 0 result(s) in 0.002188 sec, idle 1 sec]"
                 ├─ 2510 "/usr/sbin/zabbix_server: history poller #1 [got 5 values in 0.006569 sec, getting values]"
                 ├─ 2511 "/usr/sbin/zabbix_server: history poller #2 [got 4 values in 0.007523 sec, getting values]"
                 ├─ 2512 "/usr/sbin/zabbix_server: history poller #3 [got 3 values in 0.007805 sec, getting values]"
                 ├─ 2514 "/usr/sbin/zabbix_server: history poller #4 [got 2 values in 0.007122 sec, getting values]"
                 ├─ 2515 "/usr/sbin/zabbix_server: history poller #5 [got 1 values in 0.004209 sec, getting values]"
                 ├─ 2517 "/usr/sbin/zabbix_server: availability manager #1 [queued 1, processed 0 values, idle 5.635585 sec during 5.635754 sec]"
                 ├─ 2519 "/usr/sbin/zabbix_server: trigger housekeeper [deleted 0 problems records in 8.456128 sec, idle for 60 second(s)]"
                 ├─ 2522 "/usr/sbin/zabbix_server: odbc poller #1 [got 0 values in 0.000026 sec, idle 5 sec]"
                 ├─67475 sh -c "/usr/bin/fping -C3 -i0 2>&1 </tmp/zabbix_server_2504.pinger;"
                 ├─67476 /usr/bin/fping -C3 -i0
                 ├─67477 sh -c "/usr/bin/fping -C3 -i0 2>&1 </tmp/zabbix_server_2506.pinger;"
                 ├─67478 /usr/bin/fping -C3 -i0
                 ├─67479 sh -c "/usr/bin/fping -C3 -i0 2>&1 </tmp/zabbix_server_2505.pinger;"
                 └─67480 /usr/bin/fping -C3 -i0
