Interface graphs
  • ptera
    • Oct 2014
    • 109
    Interface graphs
    Running 2.4 I have interface graphs working perfectly.
    Had to make changes to the Template SNMP Interfaces in order to get snmp data from our current equipment. SNMPv1 agent instead of SNMPv2 agent.
    Decided to off load some of the graphing work to another zabbix server.
    Installed 3.0.3 on a VM and copied the settings from the Template SNMP Interfaces on the 2.4 server but now I get 5 min of graph and then 5 min of nothing. Or just spotty graphing.
    I just checked the graphs generated for the zabbix server and they shows the same problem and they are not associated with the Template SNMP Interfaces.
    I even took one of the pieces of equipment on the 2.4 server and disabled the snmp items for it thinking that having two servers doing queries was causing the delay. No change.
    The log is full of these...
     32280:20160713:151722.230 resuming SNMP agent checks on host ".35 Ptera105": connection restored
     32283:20160713:151727.205 SNMP agent item "ifOperStatus[eth1]" on host ".181 Ptera11" failed: first network error, wait for 15 seconds
     32269:20160713:151742.326 resuming SNMP agent checks on host ".181 Ptera11": connection restored
     32280:20160713:151822.294 SNMP agent item "ifOperStatus[eth1]" on host ".35 Ptera105" failed: first network error, wait for 15 seconds
     32283:20160713:151831.270 SNMP agent item "ifOperStatus[eth0]" on host ".46 Ptera111" failed: first network error, wait for 15 seconds
     32283:20160713:151846.287 resuming SNMP agent checks on host ".46 Ptera111": connection restored
     32274:20160713:151912.363 SNMP agent item "ifOperStatus[ath0]" on host ".181 Ptera11" failed: first network error, wait for 15 seconds
     32285:20160713:151927.368 resuming SNMP agent checks on host ".181 Ptera11": connection restored
     32292:20160713:151937.016 resuming SNMP agent checks on host ".35 Ptera105": connection restored
     32296:20160713:151937.333 SNMP agent item "ifOperStatus[eth1]" on host ".35 Ptera105" failed: first network error, wait for 15 seconds
     32283:20160713:151946.351 SNMP agent item "ifOperStatus[br0]" on host ".46 Ptera111" failed: first network error, wait for 15 seconds
     32293:20160713:152022.384 resuming SNMP agent checks on host ".35 Ptera105": connection restored
     32291:20160713:152031.387 resuming SNMP agent checks on host ".46 Ptera111": connection restored
     32292:20160713:152037.080 SNMP agent item "ifOperStatus[lo]" on host ".35 Ptera105" failed: first network error, wait for 15 seconds
     32267:20160713:152050.010 SNMP agent item "ifAdminStatus[eth1]" on host ".35 Ptera106" failed: first network error, wait for 15 seconds
     32292:20160713:152052.104 resuming SNMP agent checks on host ".35 Ptera105": connection restored
     32296:20160713:152052.400 SNMP agent item "ifOperStatus[eth1]" on host ".35 Ptera105" failed: first network error, wait for 15 seconds
     32297:20160713:152057.392 SNMP agent item "ifOperStatus[eth0]" on host ".181 Ptera11" failed: first network error, wait for 15 seconds
     32283:20160713:152101.415 SNMP agent item "ifOperStatus[br0]" on host ".46 Ptera111" failed: first network error, wait for 15 seconds
     32281:20160713:152105.408 resuming SNMP agent checks on host ".35 Ptera106": connection restored
    My config file...
    # This is a configuration file for Zabbix server daemon
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: ListenPort
    #	Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10051
    ### Option: SourceIP
    #	Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: LogType
    #	Specifies where log messages are written to:
    #		system  - syslog
    #		file    - file specified with LogFile parameter
    #		console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    #	Log file name for LogType 'file' parameter.
    # Mandatory: no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_server.log
    ### Option: LogFileSize
    #	Maximum size of log file in MB.
    #	0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    #	Specifies debug level:
    #	0 - basic information about starting and stopping of Zabbix processes
    #	1 - critical information
    #	2 - error information
    #	3 - warnings
    #	4 - for debugging (produces lots of information)
    #	5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: PidFile
    #	Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_server.pid
    PidFile=/var/run/zabbix/zabbix_server.pid
    ### Option: DBHost
    #	Database host name.
    #	If set to localhost, socket is used for MySQL.
    #	If set to empty string, socket is used for PostgreSQL.
    # Mandatory: no
    # Default:
    DBHost=localhost
    ### Option: DBName
    #	Database name.
    #	For SQLite3 path to database file must be provided. DBUser and DBPassword are ignored.
    # Mandatory: yes
    # Default:
    # DBName=
    DBName=zabbix
    ### Option: DBSchema
    #	Schema name. Used for IBM DB2 and PostgreSQL.
    # Mandatory: no
    # Default:
    # DBSchema=
    ### Option: DBUser
    #	Database user. Ignored for SQLite.
    # Mandatory: no
    # Default:
    # DBUser=
    DBUser=zabbix
    ### Option: DBPassword
    #	Database password. Ignored for SQLite.
    #	Comment this line if no password is used.
    # Mandatory: no
    # Default:
    DBPassword=*******
    ### Option: DBSocket
    #	Path to MySQL socket.
    # Mandatory: no
    # Default:
    # DBSocket=/tmp/mysql.sock
    ### Option: DBPort
    #	Database port when not using local socket. Ignored for SQLite.
    # Mandatory: no
    # Range: 1024-65535
    # Default (for MySQL):
    # DBPort=3306
    ############ ADVANCED PARAMETERS ################
    ### Option: StartPollers
    #	Number of pre-forked instances of pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    StartPollers=15
    ### Option: StartIPMIPollers
    #	Number of pre-forked instances of IPMI pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartIPMIPollers=0
    ### Option: StartPollersUnreachable
    #	Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
    #	At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
    #	are started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    StartPollersUnreachable=30
    ### Option: StartTrappers
    #	Number of pre-forked instances of trappers.
    #	Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
    #	At least one trapper process must be running to display server availability and view queue
    #	in the frontend.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartTrappers=5
    ### Option: StartPingers
    #	Number of pre-forked instances of ICMP pingers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPingers=1
    ### Option: StartDiscoverers
    #	Number of pre-forked instances of discoverers.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartDiscoverers=1
    ### Option: StartHTTPPollers
    #	Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    ### Option: StartTimers
    #	Number of pre-forked instances of timers.
    #	Timers process time-based trigger functions and maintenance periods.
    #	Only the first timer process handles the maintenance periods.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartTimers=1
    ### Option: StartEscalators
    #	Number of pre-forked instances of escalators.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartEscalators=1
    ### Option: JavaGateway
    #	IP address (or hostname) of Zabbix Java gateway.
    #	Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    ### Option: JavaGatewayPort
    #	Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    #	Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    ### Option: StartVMwareCollectors
    #	Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartVMwareCollectors=0
    ### Option: VMwareFrequency
    #	How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwareFrequency=60
    ### Option: VMwarePerfFrequency
    #	How often Zabbix will connect to VMware service to obtain performance data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwarePerfFrequency=60
    ### Option: VMwareCacheSize
    #	Size of VMware cache, in bytes.
    #	Shared memory size for storing VMware data.
    #	Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    # VMwareCacheSize=8M
    ### Option: VMwareTimeout
    #	Specifies how many seconds vmware collector waits for response from VMware service.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # VMwareTimeout=10
    ### Option: SNMPTrapperFile
    #	Temporary file used for passing data from SNMP trap daemon to the server.
    #	Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
    # Mandatory: no
    # Default:
    # SNMPTrapperFile=/tmp/zabbix_traps.tmp
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    ### Option: StartSNMPTrapper
    #	If 1, SNMP trapper process is started.
    # Mandatory: no
    # Range: 0-1
    # Default:
    StartSNMPTrapper=1
    ### Option: ListenIP
    #	List of comma delimited IP addresses that the trapper should listen on.
    #	Trapper will listen on all network interfaces if this parameter is missing.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    # ListenIP=127.0.0.1
    ### Option: HousekeepingFrequency
    #	How often Zabbix will perform housekeeping procedure (in hours).
    #	Housekeeping is removing outdated information from the database.
    #	To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    #	hours of outdated information are deleted in one housekeeping cycle, for each item.
    #	To lower load on server startup housekeeping is postponed for 30 minutes after server start.
    #	With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    #	In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    #	period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    # HousekeepingFrequency=1
    ### Option: MaxHousekeeperDelete
    #	The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
    #	[housekeeperid], [tablename], [field], [value].
    #	No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
    #	will be deleted per one task in one housekeeping cycle.
    #	SQLite3 does not use this parameter, deletes all corresponding rows without a limit.
    #	If set to 0 then no limit is used at all. In this case you must know what you are doing!
    # Mandatory: no
    # Range: 0-1000000
    # Default:
    # MaxHousekeeperDelete=5000
    ### Option: SenderFrequency
    #	How often Zabbix will try to send unsent alerts (in seconds).
    # Mandatory: no
    # Range: 5-3600
    # Default:
    # SenderFrequency=30
    ### Option: CacheSize
    #	Size of configuration cache, in bytes.
    #	Shared memory size for storing host, item and trigger data.
    # Mandatory: no
    # Range: 128K-8G
    # Default:
    # CacheSize=8M
    ### Option: CacheUpdateFrequency
    #	How often Zabbix will perform update of configuration cache, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # CacheUpdateFrequency=60
    ### Option: StartDBSyncers
    #	Number of pre-forked instances of DB Syncers.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartDBSyncers=4
    ### Option: HistoryCacheSize
    #	Size of history cache, in bytes.
    #	Shared memory size for storing history data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryCacheSize=16M
    ### Option: HistoryIndexCacheSize
    #	Size of history index cache, in bytes.
    #	Shared memory size for indexing history cache.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryIndexCacheSize=4M
    ### Option: TrendCacheSize
    #	Size of trend cache, in bytes.
    #	Shared memory size for storing trends data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # TrendCacheSize=4M
    ### Option: ValueCacheSize
    #	Size of history value cache, in bytes.
    #	Shared memory size for caching item history data requests.
    #	Setting to 0 disables value cache.
    # Mandatory: no
    # Range: 0,128K-64G
    # Default:
    # ValueCacheSize=8M
    ### Option: Timeout
    #	Specifies how long we wait for agent, SNMP device or external check (in seconds).
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    Timeout=30
    ### Option: TrapperTimeout
    #	Specifies how many seconds trapper may spend processing new data.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # TrapperTimeout=300
    ### Option: UnreachablePeriod
    #	After how many seconds of unreachability treat a host as unavailable.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachablePeriod=45
    ### Option: UnavailableDelay
    #	How often host is checked for availability during the unavailability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnavailableDelay=60
    ### Option: UnreachableDelay
    #	How often host is checked for availability during the unreachability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachableDelay=15
    ### Option: AlertScriptsPath
    #	Full path to location of custom alert scripts.
    #	Default depends on compilation options.
    # Mandatory: no
    # Default:
    # AlertScriptsPath=${datadir}/zabbix/alertscripts
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ### Option: ExternalScripts
    #	Full path to location of external scripts.
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    ### Option: FpingLocation
    #	Location of fping.
    #	Make sure that fping binary has root ownership and SUID flag set.
    # Mandatory: no
    # Default:
    # FpingLocation=/usr/sbin/fping
    ### Option: Fping6Location
    #	Location of fping6.
    #	Make sure that fping6 binary has root ownership and SUID flag set.
    #	Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    # Fping6Location=/usr/sbin/fping6
    ### Option: SSHKeyLocation
    #	Location of public and private keys for SSH checks and actions.
    # Mandatory: no
    # Default:
    # SSHKeyLocation=
    ### Option: LogSlowQueries
    #	How long a database query may take before being logged (in milliseconds).
    #	Only works if DebugLevel set to 3, 4 or 5.
    #	0 - don't log slow queries.
    # Mandatory: no
    # Range: 1-3600000
    # Default:
    # LogSlowQueries=0
    LogSlowQueries=3000
    ### Option: TmpDir
    #	Temporary directory.
    # Mandatory: no
    # Default:
    # TmpDir=/tmp
    ### Option: StartProxyPollers
    #	Number of pre-forked instances of pollers for passive proxies.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartProxyPollers=1
    ### Option: ProxyConfigFrequency
    #	How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
    #	This parameter is used only for proxies in the passive mode.
    # Mandatory: no
    # Range: 1-3600*24*7
    # Default:
    # ProxyConfigFrequency=3600
    ### Option: ProxyDataFrequency
    #	How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ProxyDataFrequency=1
    ### Option: AllowRoot
    #	Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
    #	will try to switch to the user specified by the User configuration option instead.
    #	Has no effect if started under a regular user.
    #	0 - do not allow
    #	1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    #	Drop privileges to a specific, existing user on the system.
    #	Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    #	You may include individual files or all files in a directory in the configuration file.
    #	Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=/usr/local/etc/zabbix_server.general.conf
    # Include=/usr/local/etc/zabbix_server.conf.d/
    # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
    ### Option: SSLCertLocation
    #	Location of SSL client certificates.
    #	This parameter is used only in web monitoring.
    # Mandatory: no
    # Default:
    # SSLCertLocation=${datadir}/zabbix/ssl/certs
    ### Option: SSLKeyLocation
    #	Location of private keys for SSL client certificates.
    # Mandatory: no
    # Default:
    # SSLKeyLocation=${datadir}/zabbix/ssl/keys
    ### Option: SSLCALocation
    #	Override the location of certificate authority (CA) files for SSL server certificate verification.
    #	If not set, system-wide directory will be used.
    #	This parameter is used only in web monitoring and SMTP authentication.
    # Mandatory: no
    # Default:
    # SSLCALocation=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    #	Full path to location of server modules.
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    #	Module to load at server startup. Modules are used to extend functionality of the server.
    #	Format: LoadModule=<module.so>
    #	The modules must be located in directory specified by LoadModulePath.
    #	It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSCAFile
    #	Full pathname of a file containing the top-level CA(s) certificates for
    #	peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    #	Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSCertFile
    #	Full pathname of a file containing the server certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    #	Full pathname of a file containing the server private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
  • ptera
    • Oct 2014
    • 109
    No help - bummer
    No help - Can some one at least point me to a prior thread that solves this issue?
