Problem with IPMI
  • h.karimi
    • Jul 2016
    • 10
    Problem with IPMI
    Hi
    I'm new in zabbix
    I installed Zabbix 3.0 LTS via it's source on Oracle linux 6.7
    ./configure --enable-server --with-oracle --with-oracle-include=/usr/include/oracle/11.2/client64 --with-oracle-lib=/usr/lib/oracle/11.2/client64/lib --with-net-snmp --with-libcurl --enable-agent --enable-proxy --with-ssh2 --with-unixodbc --with-ldap --with-libxml2 --with-openipmi --with-openssl --with-jabber --enable-java
    Uncomment it in zabbix_server.conf
    StartIPMIPollers=3
    Start zabbix-server
    11733:20160718:121923.209 Starting Zabbix Server. Zabbix 3.0.3 (revision 60173).
     11733:20160718:121923.209 ****** Enabled features ******
     11733:20160718:121923.209 SNMP monitoring:           YES
     11733:20160718:121923.209 IPMI monitoring:           YES
     11733:20160718:121923.209 Web monitoring:            YES
     11733:20160718:121923.210 VMware monitoring:         YES
     11733:20160718:121923.210 SMTP authentication:       YES
     11733:20160718:121923.210 Jabber notifications:       YES
     11733:20160718:121923.210 Ez Texting notifications:  YES
     11733:20160718:121923.210 ODBC:                      YES
     11733:20160718:121923.210 SSH2 support:              YES
     11733:20160718:121923.210 IPv6 support:               NO
     11733:20160718:121923.210 TLS support:               YES
     11733:20160718:121923.210 ******************************
     11765:20160718:121925.675 server #28 started [ipmi poller #1]
     11763:20160718:121925.676 server #26 started [ipmi poller #2]
     11758:20160718:121925.679 server #21 started [history syncer #2]
     11764:20160718:121925.681 server #27 started [ipmi poller #3]
    In frontend i added the host with
    Authentication algorithm: "defalt"
    Privilege level: "Admin"
    With HP ilo username and password
    It's connect to my my HP server but the items become support and unsuport Continuous
    Here is my "zabbix_server.log" file
    11762:20160718:135917.022 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:135939.819 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: another network error, wait for 15 seconds
     11745:20160718:135955.857 resuming IPMI agent checks on host "HP DL380": connection restored
     11759:20160718:135956.495 item "HP DL380:Fans" became not supported: sensor data is not available
     11766:20160718:140000.023 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140015.158 resuming IPMI agent checks on host "HP DL380": connection restored
     11765:20160718:140057.029 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140112.238 resuming IPMI agent checks on host "HP DL380": connection restored
     11765:20160718:140136.064 IPMI agent item "01-InletAmbient" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140151.321 resuming IPMI agent checks on host "HP DL380": connection restored
     11762:20160718:140158.153 IPMI agent item "46-ChipsetZone" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140213.364 resuming IPMI agent checks on host "HP DL380": connection restored
     11759:20160718:140221.703 item "HP DL380:Memory" became not supported: sensor data is not available
     11757:20160718:140222.705 item "HP DL380:PowerMeter" became not supported: sensor data is not available
     11764:20160718:140224.157 IPMI agent item "PowerSupply2" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140239.407 resuming IPMI agent checks on host "HP DL380": connection restored
     11760:20160718:140721.146 item "HP DL380:Fans" became supported
     11757:20160718:140722.147 item "HP DL380:Memory" became supported
     11764:20160718:140731.476 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140753.796 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: another network error, wait for 15 seconds
     11745:20160718:140809.829 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: another network error, wait for 15 seconds
     11745:20160718:140826.985 resuming IPMI agent checks on host "HP DL380": connection restored
     11758:20160718:140857.321 item "HP DL380:Fans" became not supported: sensor data is not available
     11765:20160718:140911.064 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
     11745:20160718:140926.082 resuming IPMI agent checks on host "HP DL380": connection restored
     11766:20160718:141417.031 IPMI agent item "06-P1DIMM7-9" on host "HP DL380" failed: first network error, wait for 15 seconds
    The default version of OpenIPMI in Oracle linux 6.7 is
    OpenIPMI.x86_64 2.0.16-14.el6
    OpenIPMI-devel.x86_64 2.0.16-14.el6
    OpenIPMI-libs.x86_64 2.0.16-14.el6
    How can i solve this problem?
    sorry for my bad english
    Thks
  • h.karimi
    • Jul 2016
    • 10
    Now install Zabbix 3.0 LTS source on Oracle linux7.2 with
    OpenIPMI.x86_64 2.0.19-11.el7
    OpenIPMI-devel.x86_64 2.0.19-11.el7
    OpenIPMI-libs.x86_64 2.0.19-11.el7
    The same problem the items become support and unsuport Continuous
    Plz help me
    • andris
      Zabbix developer
      • Feb 2012
      • 228
      Hi!
      Try to set "StartIPMIPollers=1" in zabbix_server.conf and see how it goes.
      Andris
      • kloczek
        • Jun 2006
        • 1771
        Plz help me
        Did you check connectivity using ipmi client?
        • h.karimi
          • Jul 2016
          • 10
          Hi
          Originally posted by andris
          Hi!
          Andris
          So many thanks
          i change "StartIPMIPollers=3" to "StartIPMIPollers=1" its works fine!!!
          why is it happen?
          If i add more IMPI device to monitor in zabbix in future with "StartIPMIPollers=1" is it work fine again?
          Yes my connectivity is ok
          • andris
            Zabbix developer
            • Feb 2012
            • 228
            HI!
            why is it happen?
            If you have 3 IPMI pollers, each of them is scanning/polling your IPMI devices on its own. Controllers in IPMI devices often cannot handle multiple parallel sessions, so you get unstable results - sometimes success, sometimes fail. Running only 1 IPMI poller solves this problem, but does not scale. It is a drawback in current IPMI poller architecture to be fixed.
            Andris
            • tserreyn
              • Jun 2012
              • 26
              confirmed- still a problem in 3.2
              Running multiple IPMI pollers still cause network errors and wholes in graphs.
              # zabbix_server --version
              zabbix_server (Zabbix) 3.2.6
              Luckily, I was just testing IPMI and not relying on it at this time.
              switching to a single IPMI poller fixed the issue.
              Curious as it looks like zabbix polls each IPMI sensor independently rather than polling all sensors in one pass then parsing it out.
              Ted
              • yujizmq
                • Feb 2019
                still a problem in 3.4.15
                # zabbix -V
                zabbix_server (Zabbix) 3.4.15
                Revision 86739 12 November 2018, compilation time: Feb 15 2019 19:59:14
                Compiled with OpenSSL 1.0.2g 1 Mar 2016
                Running with OpenSSL 1.0.2g 1 Mar 2016
