what Zabbix version number are you using ?
zabbix 3.0
To import template, are you using a xml compatible version ??
I use the template i download i just click "Import" boton and link the template
How can i check this ?
Do you have space on disk, right write permissions ??
I have 20Gb free on disk, i import from root account.
Could you attach some screenshot of the issue, for more details ??
in your case I think that the xml version isn't a problem (you could read version, opening the xml template that you want import), because you are using Zabbix 3.0.
I suggest you select ALL the checks when you are importing the IMM template.
Then, if it doesn't work well, can you attach here the template to look it in details ??
I've downloaded the IMM template from here "https://share.zabbix.com/cat-server-hardware/server-with-imm-imm2" and it works well.
