problem with forecast
  • serpentes
    • Jul 2023
    hi there,
    i have a strange problem with forecast items.
    I am trying to do a forecast for disk usages on my monitored hosts. I have working items with the free space which are of the type Numeric (unsigned)
    The problem occurs - or gets visible when the free space is above 1TB
    When I create a calculated item with the formula
    last(//ITEMKEY)
    it reads the korrekt value in Bytes - just to check if the item's value is correct - e.g. 1757956354048
    when i change the forumula to
    forecast(//ITEMKEY,1h,1h)
    and klick on "Test" and "Get Value and Test" it reads a wrong value from the key: 999999999999.999878 - which results in 931.46GB
    Seems linke forecast reading a float value although its unsigned :-/
    can anybody help me pointing this out?
