Zabbix Saml authentication with AWS Cognito
  • mfuk
    • Jul 2023
    • 18
    I'm trying to configure SAML AWS Cognito authentication with my Zabbix 6.0.20
    I copied from Federated identity provider sign-in the certificate and saved on zabbix server in: /etc/ldap/ssl/idp.crt
    I updated the /usr/share/zabbix/conf/zabbix.conf.php file as below:
    $SSO['SP_KEY'] = '/etc/ldap/ssl/key.pem';
    $SSO['SP_CERT'] = '/etc/ldap/ssl/cert.pem';
    $SSO['IDP_CERT'] = '/etc/ldap/ssl/idp.crt';
    $SSO['SETTINGS'] = [];​
    In Zabbix GUII Enabled SAML authentication​ with these parameters:
    • IdP entity ID: <User pool ID​>
    • SSO service URL: https://<cognito>.auth.<region>.amazoncognito.com/login?client_id=<client_id>&response_type=code&sco pe=aws.cognito.signin.user.admin+email+openid+phon e+profile&redirect_uri=https://<my_zabbix_domain>/index_sso.php?acs
    • SLO service URL:
    • Username attribute: userEmail
    • SP entity ID: <SAML_GROUP_NAME>
    • SP name ID format:
    • Sign
      • Messages <SELECTED>
      • Assertions <SELECTED>
      • AuthN requests <SELECTED>
      • Logout requests <SELECTED>
      • Logout responses <SELECTED>
    • Encrypt
      • Name ID <SELECTED>
    • Case-sensitive login <SELECTED>
    ​Click image for larger version  Name:	image.png Views:	0 Size:	25.7 KB ID:	468517​
    How can I enable JIT provisioning?
    When I try to login, I click on Sign in with Single Sign-On (SAML) and I redirect correctly to the Cognito authentication.
    Click image for larger version  Name:	image.png Views:	0 Size:	9.6 KB ID:	468514​
    But after login I recieve the error:
    • No permissions for system access.
    • SAML Response not found, Only supported HTTP_POST Binding​
    Click image for larger version  Name:	image.png Views:	0 Size:	6.8 KB ID:	468515​
    Could someone can help me to fix it, please?
