HistorySyncer causing false alerts
  • nms_user
    • Feb 2009
    • 43
    Hi all,
    we have a absolutely fine running zabbix installation, but since about a week, all out of a sudden, history syncer is causing myriads of false positives (.nodata - Server is down) when/during its run. Please see the attached screenshot. History cache is filling up rapidly.
    NVPS are ~770, DB is backed on a SSD-RAID1, 55GB in size.
    Here some mysqltuner output:
    [--] Reads / Writes: 77% / 23%
    [--] Total buffers: 60.3G global + 125.2M per thread (350 max threads)
    [OK] Maximum possible memory usage: 103.1G (81% of installed RAM)
    [OK] Slow queries: 0% (1/390M)
    [!!] Highest connection usage: 86% (304/350)
    [OK] Key buffer size / total MyISAM indexes: 800.0M/126.0K
    [OK] Key buffer hit rate: 100.0% (852K cached / 2 reads)
    [!!] Query cache efficiency: 0.0% (0 cached / 165M selects)
    [OK] Query cache prunes per day: 0
    [OK] Sorts requiring temporary tables: 0% (2 temp sorts / 155M sorts)
    [!!] Joins performed without indexes: 6836172
    [OK] Temporary tables created on disk: 21% (7M on disk / 34M total)
    [OK] Thread cache hit rate: 99% (841 created / 8M connections)
    [OK] Table cache hit rate: 75% (419 open / 554 opened)
    [OK] Open file limit used: 0% (19/5K)
    [OK] Table locks acquired immediately: 100% (422M immediate / 422M locks)
    [OK] InnoDB data size / buffer pool: 55.0G/58.6G
    Any thoughts what's wrong here? Are the SSD's becoming a bottleneck?
    Edit: we are on 2.2.13
