Problem in Monitoring --> Triggers
  • python05
    • Jun 2016
    hello
    I have a lot of triggers , but when I select some and change their state to Enabled , they appears for some time in Monitoring --> Triggers then they desappear again ...
    How can I make them always appear in Monitoring --> Triggers ??
    Thank you
  • Linwood
    • Dec 2013
    • 398
    At the top there is a "all", "Recent problems" AND "problem" filter. The first shows all triggers (for selected hosts and other filters) regardless of state, the latter is only those now in an alert state, and the middle one any that have been in an alert state recently even if now OK.
    • python05
      • Jun 2016
      Thank you
      but I have 2 filters only : problem and any
      It's solved anyway
      • Linwood
        • Dec 2013
        • 398
        Glad its solved, maybe you are on an older version, I know in 2.4 and 3.x there's three values.
