Regexp in zabbix trigger expression doesn't work
  • niuk
    • Jul 2016
    I have trigger expression which is supposed to generate notification when two digits found in the ssh script output
    {Checkpoint:ssh.run[vsx,10.110.1.81].regexp("\d{1,2}fwk")}=1
    but doesn't generate notifications in the case below
    CPU VSX (Checkpoint:ssh.run[vsx,10.110.1.81]): 14fwk5_dev 6fwk3_dev 0fwk0_dev 0fwk2_dev 0fwk1_dev 0fwk4_dev
    but does when change '1' t '0'
    {Checkpoint:ssh.run[vsx,10.110.1.81].regexp("\d{1,2}fwk")}=0
    also it works when I replace "\d{1,2}fwk" by "[1-9]{1,2}fwk"
    {Checkpoint:ssh.run[vsx,10.110.1.81].regexp("[1-9]{1,2}fwk")}=1
    CPU VSX (Checkpoint:ssh.run[vsx,10.110.1.81]): 31fwk5_dev 2fwk2_dev 0fwk0_dev 0fwk1_dev 0fwk3_dev 0fwk4_dev
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Problem is that frontend and server use different regular expression libraries. In your case \d is supported by frontend while server does not recognize it as "digit".
    • niuk
      • Jul 2016
      Appreciate, is there a way to use posix regex, bypass frontend ?
      • glebs.ivanovskis
        • Jul 2015
        • 237
        Simply be careful and try to stick to POSIX extended regular expressions
