Failed during the Zabbix databse upgrade
  • 954298742594
    • Aug 2023
    Hello everyone,
    I try to upgrade my zabbix from 5.0 to 6.0 and during the database upgrade, the following messages occured in the zabbix_server.log:
    database upgrade failed on patch 05010033, exiting in 10 seconds
    Current database version (mandatory/optional): 05010032/05010032
    My Mariadb version is 10.6.
    The upgrade process is blocked on that step.
    Have you any idea of what the problem could be ?
    Thanks,
  • tim.mooney
    • Dec 2012
    • 1436
    There are unfortunately a number of things that can cause schema upgrades to fail during a Zabbix upgrade. Without more information, it's difficult to guess what the cause might be.
    Are there no other error messages in the server's log, before the "database upgrade failed" message?
    Did you read the upgrade notes for 6.0, especially the part about setting a specific MariaDB/MySQL variable during the upgrade? https://www.zabbix.com/documentation...rade_notes_600
